0 1979 oil lines and vents
0 Rear Shock length '81
0 0Salt Flat Sporton
0 Woke, cancel culture...
0 Upgrade proof, evidence backed, High Flow Air Filter/intake for EFI 883/1200
Last Post: d10221
0 Change to UK petrol
0 06 1200 Won't idle when hot
13 How much will it cost? (Pan America)
Last Post: AZbiker
4 Rear Lighting WIRING help
0 Cant find (2001 Jugs/Pistons On 2005 Engine?)
0 10 things i DON'T miss about my sporties
Last Post: AZbiker
0 How many helmets?
Last Post: bordens
0 Shocks and clutch Q
Last Post: AZbiker
0 Want to rejet my 1989 883
2 Sloppy Throttle Feel
0 DK Customs Air Intake
Last Post: AZbiker
0 Mikuni HSR42 will not idle
0 Pan American Owners Manual and accessory info
0 WTB OEM 1977 Sportster handlebars
Last Post: Big Al
Last Post: Brad
nailhead (79), Rooster (64), chidovampiro (62), daniel (59), evereyken (58), RogueXR9OO (58)
ignition problem, rotor, sensor, stripped bolts
Old 26th August 2020
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Unhappy How to stripped ignition sensor pickup screw
Tearing down engine to replace parts from seized pistons when got too hot, and come to take out bolt for ignition timing pickup rotor and not stripped complete, but how would one get this thing out. tried 5/16 and also metric but 5/16 was best fit.
But bolt doesn't seem to want to budge. Used heat, tried vise grips, but kinda slip of once turns, but what would ya'll suggest or what did you do if was in same situation to get this bolt off ? I have another pickup rotor from a new ignition from a while back, but the is a allen bolt, so can't get exact size except from when tried to get off with socket that fit in the first place.
Pretty sure it turns is righty tighty and lefty loosy.
Thanks for any feedback. Gonna spray some PB blaster on it... fingers crossed.
Bolt removal by groove meisterus, on Flickr
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Drill a small hole and use reverse screw extractor ?
Old 28th August 2020
resolved with craftsman bolt extractor socket set from lowes, worked like a charm first time and no troubles
Wow! Was it that rusted?
Glad you got it out cleanly...
IXL _______ &gt;&gt;&gt;&gt; My Motorcycle Chronicles Are Here &lt;&lt;&lt;&lt;
Don’t think it was rusted, just gunk from blue lock tight over the years I can only assume
