0 Recap of my tranny repair
0 Luggage rails?
0 Shocks and clutch Q
0 83 XLH w/Velorex 562
Last Post: Scott
0 Woke, cancel culture...
0 How many helmets?
Last Post: bordens
0 1979 oil lines and vents
Last Post: Sportster79
0 Rear Shock length '81
0 0Salt Flat Sporton
0 Upgrade proof, evidence backed, High Flow Air Filter/intake for EFI 883/1200
Last Post: d10221
0 Change to UK petrol
0 06 1200 Won't idle when hot
13 How much will it cost? (Pan America)
Last Post: AZbiker
4 Rear Lighting WIRING help
0 Cant find (2001 Jugs/Pistons On 2005 Engine?)
0 10 things i DON'T miss about my sporties
Last Post: AZbiker
0 Want to rejet my 1989 883
2 Sloppy Throttle Feel
0 DK Customs Air Intake
Last Post: AZbiker
0 Mikuni HSR42 will not idle
nailhead (79), Rooster (64), chidovampiro (62), daniel (59), evereyken (58), RogueXR9OO (58)
cams, ratio, rockers, stripped bolts, stripped down
Old 5th September 2020
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Originally Posted by seajay View Post
Hammer performance did BFH work on my heads with 2.02 intakes and S&S 1.725 rockers. Running NRHS .590 cams.
I actually called Hammer Performance. Alex mentioned it could possibly be from
stock length pushrods being to tall for my setup and that ratio really shouldn't matter, but that was with my setup. Your setup probably different cause Hammer did the work maybe. I guess I could use my ole Screaming eagle -0.05" lil shorter than stock length push rods when get heads back from sending them to Branch to get rebuilt.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
rocketmangb's Avatar
Changing rocker ratio wont automatically screw up the geometry.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
When rebuilding mikes bike, we had an issue with studs stripping from cases. repaired using timeserts as they create a mechanical bond to the base material. the ones you listed from fastenal do not seem to do so, but use lockpatch to hold in place.
the time serts use both. ..
http://www.timesert.com/html/hd.html
I Have been wanting to use woods cams in a sporty build, but the steep ramps have kept me from pulling the trigger. especially since hammer made their cams with a gentle lobe on purpose..
After asking around, my solid pushrods maybe a lil too long. Hate to do adjustable, but I still have my screaming eagle -0.05" solid shorter push rods.
I think he had trouble with the rocker box to head bolts
Nope. Issue was the pushrod side rocker bolts that stripped the bolts that holds the rockers down on push rod side. Probably too long of pushrods when asking around, and probably need some roller rockers with that high of lift.
Originally Posted by kitabel View Post
it can sometimes be advantageous to change the geometry
Assuming no other changes: the valve stem height should be increased by 50% of any lift increase.
Example: original lift .458", new lift .590", difference = .132", 50% is .066"
This can be done with a lash cap (though this specific thickness cap is not available), or by lowering the entire box by milling the box base or head mating surface. The easiest method is to just use a common .060" cap as better than leaving it alone.
This will affect pushrod adjustment, and require different length non-adjutable PR.
That's what Hammer Performance mentioned about pushrod length. My stock Hammer length push rods could be a bit too tall. I still have my screaming eagle -0.05" shorter pushrods. But could try using an adjustable to start with, then measure the length then have Hammer make me some exact length pushrods.
Default Bolts
Are those not the rocker box to head bolts ?
Default Heads
Yes, it will. If it was correct before it won't be afterward.
Mighty big IF !
Yes. I read it in a way that thought was the small bolts.
They are the two main 5/16" bolts that hold down the rockers on the push rod side.
After calling around and asking questions after I made first post, leaning more towards stock pushrod length is too long. I don't want adjustables , and prefer solid push rods.
And I still have my screaming eagle -0.05" shorter push rods that I believe would help.
Best would be to use adjustable's at first. remove rocker box, pull out the adjusted push rods, then measure, the get the exact height give or take for intake and exhaust length solid one piece push rods from Hammer performance.
Smith Bros in Oregon
Default Pushrods
I might need one of these !
https://www.pushrods.net/product-pag...th-checker-kit
