0 WTF Happened
0 Howdy folks
0 Sydney and Northern Beaches riders - any around
Last Post: petersinc
0 2011 Rusty's Iron "BO883R"
Last Post: RustyFrenchy
0 07 883 Low .... lifting
Last Post: 45Brit
0 2021 Christmas List
Last Post: Brad
Last Post: Brad
0 03 xlh 88"
0 Upgrade proof, evidence backed, High Flow Air Filter/intake for EFI 883/1200
Last Post: d10221
0 This place still sucks!!!
Last Post: Bryan1976
Last Post: ronccc
0 New Owner
Last Post: Brad
0 ISO parts for my 1986 build
0 0Salt Flat Sporton
0 Keep an Old sportster or buy New
0 Can you ID this bike?
Last Post: Bigshankhank
0 Fixing or replacing primary cover for a 1975 xlh?
Last Post: randy3934
0 Normal or excessive intake valve buildup
0 Newbie seeks smoother ride
Last Post: Jerry P
0 2009 Iron 883 Wont Start!
Last Post: jsaintmartin
0 One cylinder working ...
Last Post: Bert fegg
0 Stock vs. Modified
Last Post: Blacky
ezduzit (65), Wolfden (59), dansantos99 (50), Camacho (49), RedHeep (44), cbaff (38), Elf McKuen (37)
cams, ratio, rockers, stripped bolts, stripped down
Old 5th September 2020
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I used Hammer's method #2 http://www.hammerperf.com/ttpushrodlength.shtml
Old 6th September 2020
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Lightbulb Need adjestabe Push rods or exact fit solids
Just got off the phone with bob woods cam manufacture and sure enough he said was only cause I wasn't using adjustable push rods that head bolt holes push rod would want to strip from pushing up on the rockers with them sharp ramps.
Said to get some S&S or Screaming Eagle Adjustable's, and then call him with what lifters I'm using (new S&S 2017 precision ) what the rod thread pitch is, and he would tell me how many turns to use for my bike exactly. But I'm sure the gasket thickness would be woot with hydraulic lifters.
When I mentioned what some one mentioned about rocker ratio geometry he said that's looney crazy.
We'll I think I have learned the hard way about using adjustables in the first place cause the cams circle isn't like stock he said, non concentric or some wording.
I got lucky he picked up on a Saturday, said usually closed but was doing in between dyno runs and picked up phone. Seemed pretty sure of him self in a stubborn senior man way makes one think he knows his cams.
Boy was he a fun stubborn ole Alabaman to talk with. Knew his stuff.
Still would rather go the way of using adjustable just to get the length, them custom made from the links list above from good feedback.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Originally Posted by seajay View Post
Hammer suggested that to me also, but since talked to Bob Woods himself (comment above) , adjustables to start with, then get custom length solids built.
rocketmangb's Avatar
Back to Smith Brothers !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
