0 Andrews mainshaft question
Last Post: CDeckner
Last Post: Tconnor2
0 Finally!
Last Post: weddlz12
0 66 XLCH Tank Decal correct?
Last Post: Magneto Sportster
0 super b overflow
0 PMRA Real Street Vtwin
Last Post: MatHormell
0 Hi from France
0 Newbie
Last Post: mikam123
Last Post: WI_duker
0 Clutch ramp outer
0 mystery leak
Last Post: mdub
0 WTF Happened
Last Post: WI_duker
Last Post: Four Speed
Last Post: Yakcm2
5 Jiffy Standing
Last Post: XLPIZZA
Old 13th December 2018
Will1250 Will1250 is offline
Sportster/Buell Model: XL
Sportster/Buell Model #2: XL 1200 bitsa project
Sportster/Buell Year #2: 1986
Will1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond repute
Default 2011 exhaust on 2004?
Hey boys and girls, a quick question: will a standad exhaust system off a 2011 Sportster (EFI) fit on a carbed 2004? The part numbers are different for the headers, but that could be just the sensor bungs as the bracket and muffler numbers appear to be the same.
Obviously there is the issue of the sensor bungs to deal with but are the pipe and flange diameters and angles and lengths/bends consistent between these years?
Cheers, Will
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Year #2: 2017
if you have everything (pipes, brackets) I *think* it sould fit, same frame AFAIK.
Should, recently the rear master cylinder was moved back out to the sprocket cover which might require more room, but 2011 should be good.
Folkie Folkie is offline
Yes, it'll fit exactly the same; you just need some plugs to close off the O² sensor bungs.
I did that with my '05: put on a set of Vаnce Αnd Hіnes Double Barrels, which were only available for '07+.
Thank you gentlemen, that information is good to know. A complete stock exhaust system for $100 doesn't come along all that often.
Cheers, Will.
Old 14th December 2018
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Year #2: 2016
Cheers, Will.
Yeah, if it includes the crossover pipe THAT alone is something like $300 new.
Old 15th December 2018
Yep, both header pipes, the heat shields, two mufflers and that crossover mount pipe thingy that bolts to the engine and supports the mufflers
