Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Introduce Yourself
0 Andrews mainshaft question
Last Post: CDeckner
Last Post: Tconnor2
0 Finally!
Last Post: weddlz12
0 66 XLCH Tank Decal correct?
Last Post: Magneto Sportster
0 super b overflow
0 PMRA Real Street Vtwin
Last Post: MatHormell
0 Hi from France
0 Newbie
Last Post: mikam123
Last Post: WI_duker
0 Clutch ramp outer
0 mystery leak
Last Post: mdub
0 WTF Happened
Last Post: WI_duker
Last Post: Four Speed
Last Post: Yakcm2
5 Jiffy Standing
Last Post: XLPIZZA
Old 12th January 2019
Air-Cooled Forever
And a Big Howdy from North Dakota!
Veeflys Veeflys is offline
Sportster/Buell Model: 883N
Sportster/Buell Year: 2016
Veeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud ofVeeflys has much to be proud of
Hello from Beaver County, PA! Veeflys
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Welcome from confirmed pleasant down right balmy warnings in Sou by West Fla.
My your prayers be with me.
This is THE BEST Sportster Resource!
Take a minute and please put at least your state/country in the LOCATION FIELD of your profile so we can better help you when you need it - Your climate, temps & altitude can make a difference to suggested fixes... (the STATE FIELD does not show on posts so you need to use the LOCATION FIELD)...
CLICK HERE - then scroll down to 'Additional Information' and look for the field labeled 'LOCATION' - put your information in there - It will then show on each post you make... Look for this:
Post a PICTURE of your ride... Host the image on a photo website (but not photobucket.com), get the link with the "[IMG][/IMG] tags" included & paste that directly into your posting (If you don't have the "[IMG][/IMG] tags" included, then use the Image Insert icon along with the web address of the image)...
There are various sections to the XLForum - You can pick a section that is related to your problem/info, open that section and read the sticky threads on the first page - Then post your comment in an existing thread or create a new one to get information for your specific question... For new threads, make the title specific to your problem or info...
This is the index of sections: http://xlforum.net/forums/index.php
Be sure to read some/many of the FAQ/HowTo threads here:
http://xlforum.net/forums/forumdisplay.php?f=16
The Sportsterpedia has a lot of technical info to review:
http://sportsterpedia.com
Once you look around and see the value of this place, consider becoming a paying member:
http://xlforum.net/forums/showthread.php?t=1595401
http://xlforum.net/forums/payments.php
Old 13th January 2019
oreocat1's Avatar
oreocat1 oreocat1 is offline
Sportster/Buell Year: 11
Other Motorcycle Model: Yamaha FZ-07
Other Motorcycle Year: 2016
oreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond reputeoreocat1 has a reputation beyond repute
Welcome from middle Missouri
