0 Andrews mainshaft question
Last Post: CDeckner
Last Post: Tconnor2
0 Finally!
Last Post: weddlz12
0 66 XLCH Tank Decal correct?
Last Post: Magneto Sportster
0 super b overflow
0 PMRA Real Street Vtwin
Last Post: MatHormell
0 Hi from France
0 Newbie
Last Post: mikam123
Last Post: WI_duker
0 Clutch ramp outer
0 mystery leak
Last Post: mdub
0 WTF Happened
Last Post: WI_duker
Last Post: Four Speed
Last Post: Yakcm2
5 Jiffy Standing
Last Post: XLPIZZA
  #31
Old 13th January 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief Opinion Expert
Good points. I'm going to see what I can find. The beam one I have is a big 1/2 drive one besides. I'd like to get a 1/4" drive one in in. lb.
05 1200/1250C/Hammer 570 Cams
TC88A/DCPR8EIX indexed/Taylor Pro 8mm
S&S Premium Lifters/V&H Straightshots w/HP+baffles
45/185/N65C/Dragtron II AC K&N filter
VR1 20W50/SpectroSTL 75W140
Remember when you install the lower rocker boxes to use the right bolt torque sequence.
Else you can risk stripping the threads in the heads where they bolt down.
http://sportsterpedia.com/doku.php/t...ation_sequence
