0 Andrews mainshaft question
Last Post: CDeckner
Last Post: Tconnor2
0 Finally!
Last Post: weddlz12
0 66 XLCH Tank Decal correct?
Last Post: Magneto Sportster
0 super b overflow
0 PMRA Real Street Vtwin
Last Post: MatHormell
0 Hi from France
0 Newbie
Last Post: mikam123
Last Post: WI_duker
0 Clutch ramp outer
0 mystery leak
Last Post: mdub
0 WTF Happened
Last Post: WI_duker
Last Post: Four Speed
Last Post: Yakcm2
5 Jiffy Standing
Last Post: XLPIZZA
Old 20th February 2019
harley506d's Avatar
Sportster/Buell Model: 1200c
Very interesting Fram test. With all that dedicated testing / quality control etc it's odd that they always seem to come low down on group tests/cut apart to see build quality.
Summat not right somewhere!
The Fram Ultra seems to get good reviews over at BITOG.
I believe the Fram XG3614 will fit Sportsters, 99% at 20 microns (although that model is not the part number actually tested)
http://www.fram.com/parts-search/XG3614/
FRAM Group testing of average filter efficiency of PH8A, 3387A and 4967 or equivalent FRAM TG or EG models under ISO 4548-12 for particles greater than 20 microns.
the Ultra Synthetic oil filter has the ultimate dual-layer synthetic media which provides up to 20,000 miles of engine protection.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
