0 Im done with brake bleeding.
Last Post: v3ko123
0 WTB 50 or 100 RD Drum for Thompson 1927
Last Post: seajay
0 '95 - relocated my turn signals
0 Gender sensitivity:
0 Cafe Bars/Drag Bars/T Bars
0 shift lever fabrication questions
Last Post: JonesL
5 Do you have a Facebook Acct?
Last Post: skien
Last Post: Brad
6 Custom Racer with Aluminium Frame and Sportster Engine
Last Post: agusta74
0 My '05 1200C (insert clever title here)
0 Can't find build thread for DAN MOTO’S HARLEY SPORTSTER RACER
Last Post: agusta74
0 Rear Caliper Pin Bolt Thread 2009 Nighster
0 Relocating front signals '21 Forty 8
Last Post: Morsecode
0 best way to re-route throttle cables?
Last Post: redling36
7 2001 xlh 1200 off road
0 "S" model specific Q&A
0 10 things i DON'T miss about my sporties
0 Home Brewing
0 Rocker arms bolts
0 Broken chain
0 '81 front Shocks
0 04 883
Last Post: ZCarFan
Old 2nd December 2020
Mike1nw Mike1nw is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Suzook Burgman 400/ 2008
Mike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond reputeMike1nw has a reputation beyond repute
Default Installing jugs finally but another Q
2007 883
Finally installing jugs and heads
I don't see, in the FSM, that you install each head when its valves would be shut. Which makes sense to me.
So I guess it doesn't matter where pistons are, you just bolt them on?
Highly-Dangerous's Avatar
I just posted in you "Potato - Potato" post..... I am lost now...
What are you exactly doing to your 07 883?
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
I broke off the nut on the left end of the mainshaft, in Sept.
So, had to replace mainshaft = disassembly of engine......
The cases are back together Now I'm putting jugs and heads on.
Going OK so far. But it's been slow though.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Originally Posted by Mike1nw View Post
2007 883
The crank/piston position makes no difference when installing the heads, that's correct.
However, it matters very much when installing the rocker boxes.
I know it's not our kit (at least I don't think so?), but common mistake #6 in our kit installation instructions applies anyway: http://www.hammerperf.com/ttinstallkit.shtml#mistake6
Click Here to Contact Me
Old 3rd December 2020
kitabel kitabel is offline
Sportster/Buell Year: 1989
Even the boxes don't matter, if you have adjustable pushrods.
aswracing's Avatar
You have to position the motor to adjust them anyway.
What part of my remark is wrong?
aswracing's Avatar
Who said it was wrong?
Although I could go down that path if you're interested ... but I was just pointing out that it gives no advantage, the motor is still going to need to get positioned correctly.
Old 4th December 2020
What did you have in mind?
rocketmangb's Avatar
What was the old method ?
Intake just closing adjust the exhaust
Exhaust just opening adjust the intake
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
