0 shovster ignition timing
0 e bay deals i got past 2 weeks
Last Post: mct496
0 Through The Years
0 Putting the Sport back in the Sportster
Last Post: 1Scooter
0 Latest toy arrived... 1967 Sportster XLB
Last Post: boonoorong
0 Chain: What Type?
0 A few Thoughts
Last Post: Monte03
0 Cams for a Turbo XL1200H
Last Post: casual_obser
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 A year later...
Last Post: Andy56
Last Post: gconnsr
0 trimmed shovel top hats
0 Amazon CV carb
0 Belt tension
Last Post: Bryan1976
0 Ignition circuit
0 Pipes "Wheezing" on decel
0 Buell XB top end on Sportster Who has Done It??
Last Post: Racepres
0 distributor
breakwind, OkieHD1911 (73), Sal77 (68), Jeffro (52), NYSPORTY (47), lordharley (46), gearzslyb (29)
Old 28th June 2022
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond repute
I don't believe that's a Kosman chassis.
Looks to be late 80's -early 90's Truett 3 rail.
Old 28th June 2022
Thank you.
Yes I found some very similar bikes on YouTube from 1992 but they had smaller rear tires. So I am guessing mid 90s.
Old 8th August 2022
mct496's Avatar
mct496 mct496 is offline
Sportster/Buell Model #2: 84 xl paughco rigid
Other Motorcycle Model: 70 xlch
mct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud ofmct496 has much to be proud of
Default 81-82 ironhead cases??
Unless we can figure out a way to ET race this machine it is up for sale.
He acquired it in lieu of payment for an old debt. Said something about $2800.
With the chassis pictured above.
This stuff cleans up well, some of it is brand new, I believe the Kossman chassis is a virgin as it has no seat or bodywork tabs installed yet.
Cylinders are Axtel 3.5" for 5" stroke looks like 81-82 cases setup to use the trans case as the oil tank(?) Cut down 84A cam cover high lift tappet holders, Digger Ent. trap door
Slipper clutch & basket for 3" belt, high gear mainshaft uses standard BT sprocket.
That's a 4 speed Evo case = blocked off Gen hole for oil filter mount hole behind trap door for stator wires oil drain hole in deck surface left side cylinder stud holes are out away from main case lifter block hold down bolts are offset from lifter centerline
Old 8th August 2022
Sportster/Buell Year #2: '03
good eye Mike.i can see what you pointed out here.
Old 8th August 2022
I see JACK WITT RACING, INC. as being dissolved in 1985
https://opencorporates.com/companies/us_tx/0059918800
Sister company JACK WITT RACING TIRE SERVICE, INC. dissolved in 2006
https://opencorporates.com/companies/us_tx/0122247500
Old 10th August 2022
GA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond repute
The 1st link that Hippysmack gives shows addition of John C Witt Jr added as an officer in 2021. Logging into the site provides an address for him in Pasadena, TX. Following that address, you may be able to find the answers to your questions, Chuck.
