0 low rpm problem
0 Remember these?
Last Post: Parker 1000
Last Post: vferdman
0 900cc Cylinders
Last Post: Nitro57xl
0 Anyone using the V&H FUELPAK FP3 currently?
Last Post: Sportyman13
Last Post: XL1275
0 Basket case
Last Post: randy3934
0 Runway 06 C
0 wavers
0 Hagerty Insurance
Last Post: trappnman
0 ultima install without VOES
Last Post: Bow only
0 Coil Resistance Question
0 Member "Wedge" Heads for 1275 Conversion
0 Rear wheel alignment
Last Post: v3ko123
0 Range With EFI 4.5 Gal Tank
Last Post: FiftySixer
Old 15th June 2019
mrmom9r's Avatar
mrmom9r mrmom9r is offline
MAF ? Speed Density ? MAP on an IR ?
Old 15th June 2019
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Few more pics if you guys are interested.
upload
groove for large external spiralok
[url=https://imgbb.com/]upload[/url
Roughed out man with internal o-ring for int seal. Bolts to alum flange drawing in against spiralok and sealing on outer edge of spigot. Nothing special but very secure.
upload
Next it gets machined to accept the stock throttle body seal from Buell XB9. Stock TB pops into that.
upload
Tweaked the chassis a bit.
upload
upload
Tried to keep the stock(?) tank and tray locations. Remove the cast piece and sent it off to Spacecoast to one day live again.
The list of things done is shorter than the still need to do, but Im closing the gap slowly. I have pics of the swingarm mods, the tank mounting mods, the front lower fork mods, the Boatail seat mounts, the XR tail section option mounts ect ect ect ect.....it all means nothing until it runs.
Eng internals are another story.
Old 15th June 2019
Bike Builder
Yes. was planning on a connecting tube to calm the signal. Any thoughts? Im open to suggestions.
Old 15th June 2019
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
I know from experience the long runners are nice for setup to keep the carbs away from extremities, great for torque also, but I had idle issues.
The charge would fall out of suspension at low idle.
It’s nice to be able to tuck the TBIs in close.
Old 15th June 2019
Bike Builder
I know from experience the long runners are nice for setup to keep the carbs and filters away from extremities, great for torque also, but I had idle issues.
Do you recall the lengths? I am using 4500RPM for my math and physically getting there as close to those lengths within reason. Plan is to place injectors fairly close to the heads.
Guys please keep the comments and suggestions coming. I by know means have all the answers and am completely open to input good or bad. Who knows, this all may be destined for the scrap heap and stock heads put back on.
Old 15th June 2019
Bike Builder
"The ring gear looks like a good candidate for a clutch signal. I prefer to try to make the kicker work though."
Pulled head out of ass this morn and have to retract that statement. Ring gear is a horrible candidate for clutch slip for what should have been an obvious observation. Perhaps chopper wheel on hub studs may be a better option.
Old 15th November 2019
Bike Builder
Got around to fabbing up an exhaust for my crapbox this week.
AlphaN tuning which uses TPS rather than MAP for determining load, you are not likely going to get a serviceable map signal much above idle.
MegaSquirt provides a way to blend AlphaN and SD tuning, MSExtra calls it ITB mode. (ITB = Individual Throttle Body)
MSExtra also provides a way to define a MAP sampling window, but I don't think that will help in this situation.
http://www.msextra.com/doc/pdf/Megas...ing_Up-3.4.pdf
Bike Builder
Yep, ditched the MAP, it will be direct to atmosphere and will be TPS based.
Bike Builder
This is what I am using with the data logging feature.
https://www.motec.com.au/m800/m800features/
