Last Post: ronccc
0 Vintage tires
Last Post: JonesL
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Brand new 2020 XL1200NS
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Down on oil
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
Old 15th November 2019
an ironhead that can speak rubber mount evo.sure is interesting.i only speak frame mount evo,barely.
Old 16th November 2019
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
OK. So why weren't you helping the IH design team when it really would have mattered ?
And we got stuck with these clunky tractor engines that were designed by a committee. (Two drunken sailors, 1 ten year old boy and a prostitute named Rosie.)
I'm suitably impressed with what your doing here.
Old 17th November 2019
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Had I known there was a prostitute named Rosie on staff, I might have bid on the job! No one told me that,,,
Thanks ferrous, but its really not much that hasnt been done before.
Blind Owl
Ricardo did 4 valve heads nearly 100 years ago.
Doesn't mean doing something similar now wouldn't be a good thing.
PLUS - too many interesting projects are hidden from view for far too long. And I just like anything that might improve on our tractors performance. (John Deer eat yer heart out !)
(Did you know that Rosie was a midget ?)
Bike Builder
That does it....time to dust off the resume!
Old 25th November 2019
Here's my EFI winter project
My homebrew EFI on a 600" BBF in a near minimum weight chassis, I expect that will propel us to the NHRA speed limit of the chassis.
what's in the box between the scoop with the butterflies and the top of the cast manifold?besides air.i can see where the fuel enters.
Old 26th November 2019
Air, I want to build a manifold with longer runners and a bigger plenum.
Bike Builder
Here is what inspired me to put this EFi on my bike. This Briggs engine led to over 60 million dollars of investor funding. I converted it using using a Motec M48 ECU at first running it on gasoline. I had to make the throttle body, drum up some triggers, mount all of those items ect ect. All roughed out to get through the initial testng. That was done to initiate the bleed over for our Proof of Concept injector. That injector was installed on this very briggs engine to provide valuable data to further our r&d. After a few runs our injector cooked the Mosfet drivers in the ECU leading us to work with Performance Electronics developing a 48 volt version. That Briggs then ran on Hydrogen.
The second pic is yours truly doing some work on the later Chevy 502 converted to our injector running 100% Hydrogen, hence the face shield (not that that would do much). Behind the wall directly behind me are 6 K bottles with 6000psi of pure hydrogen. You can see the injectors which supplied fuel and spark directly through the original spark plug hole. This was an unthrottled set up not relying on eng vacuum.
I figured if I could do the conversion on the Briggs, shouldnt be too hard on our dinosaurs. I work with a team of engineers who dont know a screwdriver from a can opener, so i get to attempt to turn their Solidworks fantasies into something functional (sometimes).
Mike, those are truly impressive projects. Looks like you have an interesting job.
So can you run those engines on H2O? Just throw out the oxygen part?
