0 Rear wheel alignment
0 Anyone know normal operating temp?
0 Ignition advice
Last Post: Rhode Warrior
0 Sprortster Softail 1200 with Edelbrock NOS
0 CV carb running way rich!
0 I was at the gym yesterday
0 Koso hd-01-04 2014+
8 Crankshaft Failure
0 wavers
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
0 Front Master Cyl rebuild question
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Basket case
Last Post: bill smith
0 Cv carb jetting
Last Post: mikethebike61
0 Buell Blast headlight compatibility
Last Post: apotheon
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
Old 4 Weeks Ago
Staffords Staffords is offline
Staffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the rough
Default Headwork
Looking for reccomendations on shops to rework the heads on my 900 XLCH. Needs new valves, guides, and valve seats re-cut or likely new seats installed. It seems there is no one left around here still working on these old motors.
I'm located in California but I'll ship the heads out if I have to.
Old 4 Weeks Ago
doodah man's Avatar
Have you seen this in the stickies? There are 5 listings in California...
http://xlforum.net/forums/showthread.php?t=118141
Old 4 Weeks Ago
Gold Member's Avatar
Sportster/Buell Year: 1972
I'd suggest making sure you get best quality valves and guides. I don't know why, but if you are going to be spending money on heads, the job isn't cheap in the first place, so don't use Taiwan-made valves. They might be okay, but for my money, get USA made quality parts for all the whirling internals. Get the good stuff for peace of mind.
Having said that, go do what you want. I just wanted to pipe up.
Stop by my build thread:
Old 4 Weeks Ago
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Call Perry at FLO Headworks in Oceana, CA. He's done work for my two old Ironheads and I'm very happy with his work.
Eric
Old 4 Weeks Ago
Sounds like reasonable advice!! I'm planning to run USA-made Kibblewhite valves/springs/collars/keepers/guides unless there are better options available? I'm open to suggestions.
Old 4 Weeks Ago
Eric
Is FLO Headworks still in business? Haven't been able to get a hold of him.
Old 4 Weeks Ago
Mrmom9r knows his way around a flow bench...
Hazmat Life
Old 4 Weeks Ago
that's true but he will mention that a stock 900 does not want or need port work.i would still ask him if he wants the work.
Old 3 Weeks Ago
I know Perry wanted to retire a few years ago but I sent him some barrels less than a year ago for fitting new pistons. He was still working then. He runs a small operation so he might be a bit difficult to reach.
Eric
Old 3 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
For stock stuff you might try Keenan Tatro. (Is he in the Stickies ?)
https://tatromachine.com/
And if you wanted performance work he can do that too.
