Last Post: vferdman
0 900cc Cylinders
Last Post: Nitro57xl
0 Anyone using the V&H FUELPAK FP3 currently?
Last Post: Sportyman13
Last Post: XL1275
0 Basket case
Last Post: randy3934
0 Runway 06 C
0 low rpm problem
Last Post: 1Scooter
0 wavers
0 Hagerty Insurance
Last Post: trappnman
0 ultima install without VOES
Last Post: Bow only
0 Coil Resistance Question
0 Member "Wedge" Heads for 1275 Conversion
0 Rear wheel alignment
Last Post: v3ko123
0 Range With EFI 4.5 Gal Tank
Last Post: FiftySixer
Last Post: Slytat
Old 3 Weeks Ago
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Ferrous, is that the guy from YouTube videos?? The guy that works on the bikes in the junkyard??
Old 3 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Yup - That's him.
I think he's also famous for his single cylinder Sportster Bonneville exploits.
Old 3 Weeks Ago
Bike Builder
I went and looked up some of the Bonnevillle singles videos today. I guess that is his shop and not really a junkyard. Looks like his shop has some capabilities, but man it sure looks dirty and unorganized. You can see some decent equipment in the background which shows some capabilities, but the guy is a bit on the aggressive side with some of the parts. Sounds like he has been doing it for a bit and has seen and done a bit of most. i wonder if he has any other shop hands? Looks like he could use a wlling to learn shop grunt to clean the place up following behind him. If you can get past the mess, you could probably pick up a thing or two, just not the work habits.
Interesting record chasing class racer though.
Old 3 Weeks Ago
Staffords Staffords is offline
Staffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the rough
Perry of FLO Headworks got back to me. He is still in business, and I will try to get my 900 heads off to him this week for an overhaul.
Old 3 Weeks Ago
Medyo Bastos Medyo Bastos is offline
Sportster/Buell Year: 1966
Medyo Bastos is an unknown quantity at this point
Try eBay seller leannewinters69 Tim dual plugged a set of 900 heads for me.
Old 3 Weeks Ago
his son works with him.i guess he's busy filming videos. and kicking the '61 XLCH.
Old 2 Weeks Ago
that's true but he will mention that a stock 900 does not want or need port work.i would still ask him if he wants the work.
I'm interested in this statement. Is there really nothing to gain by cleaning up the ports on a 900?! Could it actually hurt things?
I have heard that the valves are a little too large for these motors as it is, but that has more to do with the velocity of the gasses moving in/out rather than the smoothness and efficiency of the flow through the ports, right? I figure a little port work and a step up in cam profile to PB or Y cams would yield a small performance increase.
I'm not going to dual plug the heads though, as I intend to run standard 9:1 compression and magneto ignition. Do you guys think that's a mistake?
Old 2 Weeks Ago
Yes, I would dual plug an 8:1 motor.
Old 2 Weeks Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
At that compression ratio all you will gain by dual plugging is complexity.
Oh, and maybe 1 or 2 hp.
Your plan sounds fine to me.
Old 2 Weeks Ago
Blind Owl
If your planning on running a Magneto dual plugging becomes a bit expensive.
It can be done of course but the only commercially available solution I'm aware of is Morris's option requiring two MSF single fire units.
If I could find someone who could supply diodes big enough for the job I could make my own - but haven't managed so far. (Dave's not about to tell me where he gets his)
Paying someone to port Ironheads makes little sense unless your building a bigger engine. Really good porting work is expensive and I would only consider paying top dollar for an engine going to be raced.
