Last Post: ronccc
0 Vintage tires
Last Post: JonesL
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Brand new 2020 XL1200NS
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Down on oil
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
Old 2 Weeks Ago
Sportster/Buell Year: 1969
RicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud of
What are you building this bike for, street cruising or racing? If street cruising don't waste your time and money on dual plugs. As far as cleaning up the ports is concerned go for it. I don't care if you're building a Briggs and Stratton lawn mower motor cleaning up the ports will always be of a slight increase in performance somewhere in the rpm range. Cleaning up does not mean reshaping, it is removing casting slag, blending port into valve seat and fitting intake manifold. If tools are available polish the exhaust port and texture the intake. Again build the engine for the purpose.
Old 2 Weeks Ago
Gold Member's Avatar
Sportster/Buell Year: 1972
One suggestion I would make when you gt your heads back is to oil them immediately and liberally. When I got mine back I had no idea they had been cleaned so well there was no oil on them, and I got some surface rust which comes right off with an oily fingertip, but still. Kind of aggravating as indie didn't say anything about that.
Stop by my build thread:
Old 2 Weeks Ago
Staffords Staffords is offline
Staffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the roughStaffords is a jewel in the rough
Originally Posted by mrmom9r View Post
At that compression ratio all you will gain by dual plugging is complexity.
Oh, and maybe 1 or 2 hp.
Your plan sounds fine to me.
Thank you. I was hoping you'd chime in.
The bike will be used for some spirited riding on short trips and maybe some dirt road riding. 9:1 compression, magneto ignition, and probably a 19t front sprocket for a little extra fun off the line. I realize the headwork isn't necessary by any means but the heads are getting new valve seats anyways might as well have the work done while it's all apart.
Old 2 Weeks Ago
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Sounds to me like the 19T is going to be the best return for smiles per mile for your plan. Save the dual plug money and spend 2% of it on an 18T for the big grin dirt riding days! Screw on the tire and drop the pressure on those days for some real grins!!
Old 2 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
No, No, NO.
That's a VERY dangerous place to ride a motorcycle. I have seen the insurance statistics.
Old 2 Weeks Ago
Bike Builder
Insurance salesmen are great for traction...
Old 2 Weeks Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
Plus one on the 18 and the dirt.
Old 2 Weeks Ago
Blind Owl
Well, maybe it's just because I'm hopeless in the dirt.
I did try but it seems that more power in the dirt just makes me crash faster.
Old 2 Weeks Ago
I have an 18 on the trans, 48 on an 18 inch wheel. Happy spot is 55 mph. Goes from happy to apeshit at 60. lol.
Old 2 Weeks Ago
I've never run 18t front sprocket but I've run a 19t with the standard 51t drum on my old 78 XLCH. Plenty of giddyup and still cruised well at 60-65.
