0 900cc Cylinders
Last Post: Nitro57xl
0 Anyone using the V&H FUELPAK FP3 currently?
Last Post: Sportyman13
Last Post: XL1275
0 Basket case
Last Post: randy3934
0 Runway 06 C
0 low rpm problem
Last Post: 1Scooter
0 wavers
0 Hagerty Insurance
Last Post: trappnman
0 ultima install without VOES
Last Post: Bow only
0 Coil Resistance Question
0 Member "Wedge" Heads for 1275 Conversion
0 Rear wheel alignment
Last Post: v3ko123
0 Range With EFI 4.5 Gal Tank
Last Post: FiftySixer
Last Post: Slytat
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
Old 2 Weeks Ago
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant future
My rear mount has been cracked in the usual place for years, I didn’t have a replacement when I noticed the flaw the last time that I had the motor out so I just refitted it, the crack never got any worse.
.......Davi.
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
I ended up pulling the engine and am very glad I did. Don't know what I was thinking. Cutting out that mount was a challenge with the engine out. Used an angle grinder with cutting wheel, chisel, and hammer. Got one tiny nick in the case that no one, especially me, will see. Should have done this when the cases were apart! I appreciate the sage wisdom on here.
were you able to remove the studs?
I didn't try. I had read from enough people that it was more difficult that I wanted to try. Everything worked out fine. Pingel is already in place.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Oh _ I can see the crack now ! .
Wow, that didn’t look good, glad you’re back on top of it, let the bonding continue.....
jsandidge's Avatar
jsandidge jsandidge is offline
Other Motorcycle Model: Suzuki GS850GL
Other Motorcycle Year: 1982
jsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to all
I haven't seen the pingle. Do the studs not go through it like on the stock mount?
The Pingel is very similar to the stock mount. A key difference, besides it’s added strength, is that you can remove and install it without splitting the cases. The aluminum surrounding the top stud hole on the stocker prevents that.
ferretface's Avatar
If the engine + Pingel installed is still out, could you post a pic of it???
