Last Post: ronccc
0 Vintage tires
Last Post: JonesL
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Brand new 2020 XL1200NS
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Down on oil
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
Old 2 Weeks Ago
ferretface's Avatar
Thank You! I have never seen a Pingel before.
Wow. It is wholly unlike the mount on my Sportster.
Where exactly did the OEM mount crack/break? I looked at the pics in the Sporsterpedia.
http://sportsterpedia.com/doku.php/t...k:ih:engmech09
I'm just curious if yours cracked/broke in the same place.
Old 2 Weeks Ago
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Mine never cracked. The steel threaded inserts at the bottom of the mounts were cockeyed and not centered (I learned after I pulled the engine). I could have fixed the stock one, but I had to remove the engine anyway, and figured it was a good time to upgrade to something that won't break. Plus, my engine should make a bit more power than a stock IH and I've read on here that the stock rear mounts are marginal on a stock engine.
Old 2 Weeks Ago
ferretface's Avatar
Originally Posted by Scott View Post
Mine never cracked....my engine should make a bit more power than a stock IH and I've read on here that the stock rear mounts are marginal on a stock engine.
I'm in the process of printing out the Sportsterpedia article that hippysmack linked. The sequence of bolt tightening of the various motor mounts seems to be of major concern. I'm going to be removing the two forward front motor mount bolts soon and I want to get it right the first time. I'm hoping I won't have to undo any others. Especially the rear ones.
