Last Post: soundnav
0 Early Sportster Shock Absorber Disassembly
Last Post: soundnav
0 Rear wheel alignment
0 Anyone know normal operating temp?
0 Ignition advice
Last Post: Rhode Warrior
0 Sprortster Softail 1200 with Edelbrock NOS
0 CV carb running way rich!
0 I was at the gym yesterday
0 Koso hd-01-04 2014+
8 Crankshaft Failure
0 wavers
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
0 Front Master Cyl rebuild question
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Basket case
Last Post: bill smith
0 Cv carb jetting
Last Post: mikethebike61
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
Old 2 Weeks Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
Default Whaaaat ???
DSC00272 by don rothwell, on Flickr
Mikuni dual throat 35mm throttle body about to become 38mm D.T.B.
Old 2 Weeks Ago
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Let the games begin!
Old 2 Weeks Ago
Sportster/Buell Year: 1969
RicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud of
I thought this site frowned on porn.
Old 2 Weeks Ago
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
keep talking,,,,, i,m almost there,,,,,,,,
Old 2 Weeks Ago
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to behold
The Mikuni is PHH, or ?
Are the runners separate right into the intake ports, or merged?
Old 2 Weeks Ago
mrmom9r's Avatar
Mikuni EFI with I.R manifold from Bolt 950.
Strange going on's on my dining room table.
Old 2 Weeks Ago
Bike Builder
Is it going back on the bolt or an HD transplant?
Wouldn’t mind hearing the exploits if it’s the latter.
Old 2 Weeks Ago
mrmom9r's Avatar
Well, the answer may be both. I am looking into some Bolt hop up possibilities for a company and this is one aspect.
It's not possible IMO to do an I.R. setup between the cylinders of an IH , just not enough room for the runners. HD tried it , I had one , it was not an improvement . The Bolt is a 60 degree v twin with way more room for intake runners and yet it's still the limiting factor in this design. The manifold is the poorest flowing component.
This thing could work using a mini plenum on an S&S manifold. But the easy path is most likely adapting an 883 EFI .
But the dual throat has more visual impact.
Old 2 Weeks Ago
Bike Builder
I most certainly wouldnt mind if you would critique my project a bit more. Good, bad or indifferent.
Old 2 Weeks Ago
mrmom9r's Avatar
Mike, I'd be glad to look at anything you've got. You can PM me or we can do it here if you don't mind people eves dropping .
I said earlier that the Bolt manifold was the worst flow restriction and that's not correct on the stock engine. The 35mm throttle body is worse but an increase in area of 14% will cure that.
