0 900cc Cylinders
0 tachometer on 2012 Custom
0 Remember these?
0 low rpm problem
Last Post: vferdman
0 Anyone using the V&H FUELPAK FP3 currently?
Last Post: Sportyman13
Last Post: XL1275
0 Basket case
Last Post: randy3934
0 Runway 06 C
0 wavers
0 Hagerty Insurance
Last Post: trappnman
0 ultima install without VOES
Last Post: Bow only
0 Coil Resistance Question
0 Member "Wedge" Heads for 1275 Conversion
0 Rear wheel alignment
Last Post: v3ko123
0 Range With EFI 4.5 Gal Tank
Last Post: FiftySixer
hand controls, switch replacement
pdonahuejr pdonahuejr is offline
Sportster/Buell Model: Ironhead Sportster
Sportster/Buell Year: 1976
pdonahuejr is an unknown quantity at this point
Default Hand Controls
I want to change the original hand controls to new chrome controls. 2 issues:
1 - the brake switch threaded insert is too small. What size thread is it and I'll retap it.
2 - The horn and left turn buttons seem to be mysteriously attached to the case. I can't pull them out. How do I get them out?
Thanks.
doodah man's Avatar
welcome to the forum p.d.jr. the thread pitch for the stop light switch is 1/4-32 NS. re #2, are you referring to removing the buttons or the switches? the buttons just pull straight off, and the switches should be held from the back with a retainer fastened with a small screw.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Control switches are the "junkiest" thing on a Harley.
The stop switch is too small and delicate, putting the little buttons back on afterwards is a real pain. There isn't enough room for all the wiring. Everything is too delicate and cramped and just junk.
