0 How you can easy get yours harley davidson!
Last Post: BobHarts
14 sdfsdfsd
Last Post: BobHarts
0 Easy Brackets on 93 Sporty
0 Rear wheel alignment
Last Post: v3ko123
0 Sprortster Softail 1200 with Edelbrock NOS
Last Post: Randy_rots
Last Post: soundnav
0 Early Sportster Shock Absorber Disassembly
Last Post: soundnav
0 Anyone know normal operating temp?
0 Ignition advice
Last Post: Rhode Warrior
0 CV carb running way rich!
0 I was at the gym yesterday
0 Koso hd-01-04 2014+
8 Crankshaft Failure
0 wavers
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
0 Front Master Cyl rebuild question
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
brendan brendan is online now
Sportster/Buell Year: 1967
brendan is an unknown quantity at this point
Default What is required to convert from manual advanced mag to fixed mag?
Hi all,
I've got a 67 which has a mag that can be manually advanced for starting but I do not have the original handlebar controls. I'd like to convert my mag over to the fixed mag base, as my adjustable one seems to allow the mag to wobble around a bit. Even after tacking the base there is still a bit of play side to side on the mag.
What parts do I need to accomplish this swap? I got pretty deep into google but haven't been able to find a solid answer thus far.
Brendan
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
If your are looking for a permanent quick job with components on hand, I believe you can machine a few thou off of the thickness of the ring the mag is bolted to. I have only fixed mags, so I have nothing to ook at currently, but I know I have done it in the past with the hex drive style adjustable mags. Removing the few thou will allow the mag base to be tightened against the body.
not sure if that explanation comes through clearly
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant future
Bike Builder
Maybe explanation was not clear enough.
The ring portion is thicker than the fixed portion attached to the cam cover. Removing a few thou will allow it to clamp tight against the fixed portion. Hence securing it in a fixed position.
Funny enough?
mikethebike61's Avatar
If the mag cannot be moved....how the hell are you going to start the beast when it's warm and 45 degrees of ignition lead?
Use a diesel shut-off (choke) cable from Tractor Supply and make a mount for it....damn site easier than what you are thinking about doing
Haven't run into starting issues with the adjustment plate tack welded yet! (:
Funny enough?
Having a difficult time comprehending it without looking. Going to take a look when I'm back home and hopefully this will make more sense.
Captain Johnny Captain Johnny is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Triumph Sprint 900
Other Motorcycle Year: 1998
Captain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to behold
Not hard starting a magneto at full advance. Myself and others here run full advance at starting regularly. I'm running an S&S Super B with no accelerator pump. Usually starts within 3 kicks.
What Iron MIke is suggesting makes perfect sense. To make it happen you need to thin the ring on the top side.
If you don't want to modify any parts a shim on top of the adapter plate that's bolted to the cam cover would lock it up too.
Or you could buy a 29600-62 plate.
https://www.ebay.com/itm/NOS-Harley-...-/352589438405
I won't debate whether you should do this or not, but I'll say that the very early sportsters came with fixed mags. I believe the first year for the manual retard/advance was 1965, and they do wobble a little.
