Last Post: XL1275
0 Basket case
Last Post: randy3934
0 Runway 06 C
0 low rpm problem
Last Post: 1Scooter
0 900cc Cylinders
0 wavers
0 Hagerty Insurance
Last Post: trappnman
0 ultima install without VOES
Last Post: Bow only
0 Coil Resistance Question
0 Member "Wedge" Heads for 1275 Conversion
0 Rear wheel alignment
Last Post: v3ko123
0 Range With EFI 4.5 Gal Tank
Last Post: FiftySixer
Last Post: Slytat
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
0 tachometer on 2012 Custom
Last Post: The Doctor71
ajsstormer ajsstormer is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: H-D Sprint
Other Motorcycle Year: 1972
ajsstormer is an unknown quantity at this point
Default Paint Code for 1976 Sportster
Anybody have information on paint codes for a 76' Sportster? Interested in a local custom paint shop re-painting my bike in another original H-D color that was available on 76' Sportster's using modern paint that is currently available.
http://www.hdpaint.tk/
ferretface's Avatar
ferretface ferretface is online now
Interesting question: Why doesn't the H-D parts catalog list paint??? Don't the dealers stock paint??? Even rattle cans???
My ride is 'black', but whose I don't know. After 37 years, I expect it's been repainted several times.
Hippysmack's Avatar
Because they covered paint codes in Parts and Accessories Bulletins instead.
http://sportsterpedia.com/doku.php/techtalk:refaint02
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I like "Wildfire Super X Candy Apple Metallic Cerise over a gold base"
Paint code is 1. (My codes)
Parker 1000 Parker 1000 is offline
Sportster/Buell Model: Xlh/Xlch
Parker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to behold
Black is Black. Very little color shade difference. For example- blue has a million shades.
ferretface's Avatar
Back in the 80's, I owned a 1975 Trans-Am, which I repainted with the black & silver color scheme of the 75th anniversary Corvette (but flipped). I used a new [at the time] paint from Dupont called 'Imron', a two-part catalyst activated resin-based paint system. Imron black left a smooth and visually 'wet' finish that was hard and scratch/impact resistant. Five years later it still looked wet and like just-painted.
If I were to strip the tanks and fenders of my Sportster, I would re-do them in black Imron.
Another way to obtain an original color sample is to look for a NOS AMF Spray can in the color that interest you. Although the paint can has most likely lost its aerosol pressure, you can use the "Cap" for a near perfect color match.
