0 900cc Cylinders
0 Runway 06 C
Last Post: Hellbent_4
0 wavers
0 Hagerty Insurance
Last Post: trappnman
0 ultima install without VOES
Last Post: Bow only
0 Coil Resistance Question
0 Member "Wedge" Heads for 1275 Conversion
0 Rear wheel alignment
Last Post: v3ko123
0 Range With EFI 4.5 Gal Tank
Last Post: FiftySixer
Last Post: Slytat
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
0 tachometer on 2012 Custom
Last Post: The Doctor71
0 Early Sportster Shock Absorber Disassembly
Last Post: Heff
Whitewalls's Avatar
Sportster/Buell Year: 1971
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
Default Pre-ride inspection importance.
Was just getting ready for an all day ride. While checking the air in the front tire I noticed the clutch cable frayed and only holding by a few strands. No ride today. Instead I'll be removing the primary cover and calling Barnett to order a new cable Monday morning.
This is a Barnett cable with about 3 years/ 5100 miles
Whitewalls's Avatar
https://live.staticflickr.com/65535/...ec2030c6_m.jpg
Get the length right, no sharp bends, especially at the lever.
Get a longitudinally wound cable with a liner.
Whitewalls's Avatar
I believe I have the length right. The cable is + 2 inches to accommodate my tracker handlebars. I keep it adjusted correctly and it always operates smooth and easy. It looks like the cable crimp failed. According to Barnett all of their control cables are longitudinally wound with liners.
When I call Monday I will confirm.
Thanks.
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
Glad you found that before setting out. I had my clutch cable break at the lever and wound up driving through the door of a hot dog place. Fortunately someone held the door open for me.
Many don’t know that these little emergency repair ends exist. I always have one in my little road kit...
https://www.jpcycles.com/product/520...amp-repair-kit
Once I learned how to silver braze and got my own torch, I stopped relying on swaged cable ends and started doing my own. I could have repaired your cable for you in a couple minutes and IMHO had it better than new. Just a little bit shorter.
'54 KHK (Current Build) '76 XLCH (sold), '13 XL Seventy Two, '97 Honda Valkyrie. I’m Retired 🥃
Whitewalls's Avatar
I'll definitely be getting one of those emergency repair ends for my tool pouch.
Thanks!
Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
If the failure was at the lever end, be sure you have the pivot pin installed in the correct direction. If installed backwards, it will rub and wear the cable. It shows correct installation inst in the manual.
Nibelungen's Avatar
Sportster/Buell Model: xl883n Iron (2019 engine)
imho
pre and post ride inspection is paramount... in every kind of bike...
that's the difference between a motorbike rider... and a car driver occasionally on two wheels...
on the lion's corpse celebrate the dogs... still the dogs are dogs and the lion a lion...
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Glad to hear you caught that. A pre-ride inspection recently showed that I lost my rear axle nut on a previous ride.
Pre-ride inspections are crucial!
Old 3 Days Ago
kmul kmul is offline
Sportster/Buell Model: xlx
Sportster/Buell Model #2: XLH
Other Motorcycle Model: FLHR, BD Vintage, 59 XLH
Other Motorcycle Year: 1998
kmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to behold
yeah ok. not running the isle of man everyday so my pre-inspection a little less compulsive. walk up to bike. can see air in tires, if sportster look in gas tank, does engine start-yes, oil pressure-yes, touch cylinders with fingers till some warmth. pre-ride-inspection complete.
