0 Vintage tires
Last Post: ronccc
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Brand new 2020 XL1200NS
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Down on oil
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
Larry May Larry May is offline
Sportster/Buell Year: 1968
Other Motorcycle Model: knucklehead
Other Motorcycle Year: 1936
Larry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud of
Default 77 XLT smokes a lot on start up
My 77 xlt, milage only 16k, smokes a lot at start up, blue or white smoke, but then clears up after about 1/2 mile or so. Any recomendations on additives, I am not really interested in doing a top end since I only ride it sparingly, thanks, Larry
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Unusual for an engine with such low mileage.
Normally, smoe on startup that goes away in a few seconds is valve guides.
But worn rings, bor problems will cause smoke until the pistons heat up.
Get someone to follow you once the engine is warm. Bring it up to 4-5 grand in third and snap the throttle shut. If it smokes when you do that, it's rings/piston/bore.
Kingrabbit's Avatar
Kingrabbit Kingrabbit is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: Honda CB550
Other Motorcycle Year: 1974
Kingrabbit is an unknown quantity at this point
Default The Smoke
Following your thread. Mine starting doing the same thing halfway through summer. It’s a 73 XLH and was running well.
Mine starting blowing oil through the rocker box gasket and the exhaust on the front cylinder.
So oil in the combustion chamber. Not going to heal is it?
Get the wrenches out!
mine only does it if sits for several days, when I ride it daily it does not smoke
what oil are you using? aren't the gerotor oil pumps also known to wet sump occasionally?
