0 Rear wheel alignment
0 Anyone know normal operating temp?
0 Ignition advice
Last Post: Rhode Warrior
0 Sprortster Softail 1200 with Edelbrock NOS
0 CV carb running way rich!
0 I was at the gym yesterday
0 Koso hd-01-04 2014+
8 Crankshaft Failure
0 wavers
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
0 Front Master Cyl rebuild question
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Basket case
Last Post: bill smith
0 Cv carb jetting
Last Post: mikethebike61
0 Buell Blast headlight compatibility
Last Post: apotheon
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
Old 24th January 2009
MouseChez MouseChez is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1978
MouseChez is an unknown quantity at this point
Talking big bore question
I have to rebuild my 74 XLCH and want to go with a bigger bore. would like to know if i can use evo jugs under my irons to get there.....any suggestions except KMA wold be real kool .....thanx ....Keep the shiny side up
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
NO EVO,
It's a Different animal, not too many shops are supplying big IronJugs these days, Ron Trock was big on this as well as D&S Cycle but not sure these days, for more performance you may consider to stroke the motor, S&S still sells Iron Kits as well as 1000cc size (3 3/16) stroker pistons, I am half way there on a motor I have, you take the 1000cc jug and lower the oil drain hole, it's all on S&S Cycles Instructions, I am sure many will chime in. popular strokes are 4 1/2" or 4 5/8, 72 0r 74 cubic inches.
plenty for the street but you need to make the other components strong to take the power produced.
thanx Mont.............Cant get the rpms w/ just the stroker though.............any other? .... thanx man
heard that Shovel jug could work but cant find the info on how to now.......any links? ..... thanx agin
Rubik's cube?......I screwed it!!
oops....wrong forum.hehehehe
Old 25th January 2009
ISBN 0-7603-2353-4 Harley Davidson Sprotster Performance Handbook, Chapter 6
ISBN 0-933078-12-9 V-Twin Thunder
Read up on performancing your IronHead before deciding what to do.
Monte03's Avatar
Default Big Bore Iron
No Dis but for you to ask if an EVO jug can fit an Iron tells me that you need to learn a bit more about Ironheads, you already have the later cases that is an excellent foundation, I would suggest learning more and considering squeezing every inch out of the stock displacement, personally I like to strip a Sportster down as light as possible = faster bike.
Sportsters are not high reving bikes but you can create a beast with a strong mid range to redline with a good head porting, choice of cams, etc.. for the street it would be smart to compromise so you can have a strong bike that can also run on the highway... learn more brother before you spend the $$$$
im trying to get the bigger bore.....i'd rather not change the stroke......i know it's been done for many years with shovel jugs.........just wanted to know if anyone ever did it with evo jugs (3.5 bore)
does anyone have the specs from troc for the shovester?.....or lead on axtel big bore jugs?....thanx
