Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Project
0 Efi and carbs
0 Replacing Oil Tank
0 Converted 883, head questions
0 Hey everybody!
0 super b overflow
Last Post: RussW
0 Kickstarter return spring
0 Need to part with my '59
Last Post: BWP 5p
Last Post: old dog
0 What Petcock
0 Do people notice your bike?
0 7 Dead and more wounded
Last Post: tvon
Last Post: Thirdbrick
0 Sportsterpedia Progress
Last Post: gravydog
0 Rear master cyclinder bore size
0 Primary/gearbox chirp
Last Post: davixlrtt
0 ***DK CUSTOM PRODUCTS Plug-N-Play for Dyna & Softail Coil Relocation!***
0 DK Coil and Coil/Key Relocation Customer Review and Pics
0 ***DK Custom Products V-Coil Relocation Kit for Sportsters***
0 New User, New Parent of an Abused Horse...
Last Post: KevinRandall
0 Hi
0 Riding in The Heat!
toby61, Stairman (74), Greywolf (70), federico (67), Big D (66), robin82732 (55), jbd777 (49), Steve3888 (47), RIORoosen (45), NXC1978 (41), JeffsJeep04 (34), Matt.loup.t
Old 20th December 2018
Randy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of lightRandy_rots is a glorious beacon of light
Originally Posted by JeremyConnors View Post
Subscribed. And hoping this project is ongoing..!
Hi
It's almost done but I still need to fine tune the fuel maps.
I need to wait for spring to do it because it's too cold and too wet now.
Thanks!
Old 24th January 2019
Blue Scoot's Avatar
Blue Scoot Blue Scoot is offline
Sportster/Buell Model: XL883N
Blue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant future
I know it's not spring yet, but have you made any more progress?
Keep us updated when you do since I would really like to know how this is working for you!
-Sent from my BlackBerry
2013 Iron 883 currently @108k miles and counting...
JeremyConnors JeremyConnors is offline
Sportster/Buell Model: XR1200
Sportster/Buell Year: 2012
JeremyConnors is an unknown quantity at this point
Default I understand...
Originally Posted by Randy_rots View Post
Hi
Thanks!
This isn’t BadWeatherBikers afterall.
(I trust you’ll get that reference.)
Old 25th January 2019
It's not that I don't ride it in the rain
It is simply too dangerous to road test and log with WOT on wet road
I will be working on it as soon as the weather will be good again.
This guy was helping me to tune it:
https://www.buelltooth.com/tunabuell.html
Unfortunately, he started to give up when his tunes were not working too well with my own Innovate dual wide band sensors :/
I think that everything was going well, but because we had to stat over at least 3 times and then stop because we needed bigger injectors, then new ignition maps and I went away for vacations, he has lost his faith...
I still have left 3 sessions paid and I hope he won't let me down.
After all it was his own decision to try to tune it with my Innovate dual wide band sensors. I was prepared to buy his own tool to do it but he wanted to give it a shot.
Pitty, that it turned out to be too difficult for him to figure out the other system :/
I have spent too much time and money to give up at this point, so I will get it done no matter what
Regards
Old 7th February 2019
firemanjim firemanjim is offline
Sportster/Buell Model: S-2
firemanjim has disabled reputation
Not sure why he could not use the Innovate wide bands, they all output a 0-5 volt signal. And I bet you can look up what voltage equals what AFR on Innovate site.
Old 16th February 2019
Hi
I set up both wide bands correctly, and I sent him loads of data.
I was feeling improvement each time I burned updated maps.
The problem was that we have done about 4 sessions and found out that the injectors were too small, so I installed new set and we had to start over again.
Then after about 4 sessions he has decided to use new timing maps from Hammer Perf and... we had to start over again, LOL.
We have done another few session and the bike started to run better and better, after each session. However, I ran out of time and we stopped with intention to continue after my vacations. Unfortunately when I got back, he was reluctant to continue :/ He still owe me few sessions and I hope he will do it for me this spring.
Regarding the Innovate, he was complaining that it gives him slightly different data than his own wide band kit, hence the problems with quick tuning.
I told him right on the start that I can buy his wide band kit if he wants but he said that Innovate should be fine...
There's also some problems with idle that he has promised to fix.
I think that I will contact Andy Whittle (the Youtuber) and send him my maps to analyze, looking from his videos, he has enough knowledge to recognize the problem right away. I'm not sure if he will be willing too do so.
Regards
