0 Efi and carbs
0 Replacing Oil Tank
0 Converted 883, head questions
0 Hey everybody!
0 super b overflow
Last Post: RussW
0 Kickstarter return spring
0 Need to part with my '59
Last Post: BWP 5p
Last Post: old dog
0 What Petcock
0 Do people notice your bike?
0 7 Dead and more wounded
Last Post: tvon
Last Post: Thirdbrick
0 Sportsterpedia Progress
Last Post: gravydog
0 Rear master cyclinder bore size
0 Primary/gearbox chirp
Last Post: davixlrtt
0 ***DK CUSTOM PRODUCTS Plug-N-Play for Dyna & Softail Coil Relocation!***
0 DK Coil and Coil/Key Relocation Customer Review and Pics
0 ***DK Custom Products V-Coil Relocation Kit for Sportsters***
0 New User, New Parent of an Abused Horse...
Last Post: KevinRandall
0 Hi
0 Riding in The Heat!
toby61, Stairman (74), Greywolf (70), federico (67), Big D (66), robin82732 (55), jbd777 (49), Steve3888 (47), RIORoosen (45), NXC1978 (41), JeffsJeep04 (34), Matt.loup.t
Old 18th May 2019
Sportster/Buell Year: 1991
It sounds like your switch works fine, it's just designed to be pushed in to be "OFF" and extends as you pull the lever to switch to "ON"
John
Old 18th May 2019
wedge's Avatar
wedge wedge is online now
So, when you press the front brake switch in, & the Brake Light goes out, THEN (while holding that front brake switch in) does the rear brake work?
You see, the front brake switch is a NORMALLY CLOSED switch - meaning, when not pressing it, it is conducting power - And when you press the button, the circuit is broken (the contacts inside are open)...
This is needed because when the front brake lever is not pulled, it holds that switch in, and when the brake lever is pulled, it allows the switch button to come out... So, the lever keeps the switch pressed (OPEN) and when pulled allows the switch button to be released (CLOSED) which sends power to the brake light...
So, you need to manually press the front brake switch in to test the rear brake switch...
That does sound like the answer, they seem to have sent him a normally open switch. Your question about him holding the front brake lever and hitting the brake pedal is the key, has that test been done?
Old 19th May 2019
Not quite ---- He doesn't have the switch mounted in place - So the lever is not part of the equation...
AT THE MOMENT, when the keyswitch is turned ON, the brake light comes on - When he presses the button - which he is holding in his hand - the brake light goes out...
THIS IS THE RIGHT OPERATION...
WHEN THE SWITCH IS MOUNTED CORRECTLY, and the lever is not pulled, the lever holds that button in and the Brake Light is NOT ON - when the lever is pulled, THEN the switch button is released & the switch contacts close and the power is sent to the Brake Light...
From the Sportsterpedia section on the Brake Light Switches:
http://sportsterpedia.com/doku.php/t...h_-_front_rear
Old 19th May 2019
wedge's Avatar
Well, yeah, I didn't get that the switch wasn't mounted. So everything seems copasetic, nothing to see here, done deal, wash our hands and go get a beer...
Old 20th May 2019
Johnmotoguy Johnmotoguy is offline
Johnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud ofJohnmotoguy has much to be proud of
When i push in the lever button and press the back brakes it does work now. When i put it all together the front brake lever doesn't work but the back brake works fine.
Let me verify a couple things:
1) You bought a direct replacement switch - from HD (71590-92A)?
2) When both brakes are released - the light is still ON
3) When you press the front brake lever, the light goes off
4) No change when you press the rear brake...
The front switch is tricky getting it to mate correctly with the lever - The manual mentioned about putting a piece of cardboard into the switch/lever cavity to keep the proper orientation...
When you reassemble a new switch in there, it's important to get the switch properly oriented so the lever activates it correctly...
Now, double check your alignment of the front brake switch to the lever...
See this thread (later model but same principle)
http://xlforum.net/forums/showthread.php?t=500998
1995 Sportster 1200 with Fatbob tank
Old 20th May 2019
Then you're not mounting the switch properly for the lever to work...
This is a STOCK LEVER, right? With STOCK SWITCH HOUSING, right?
If the Rear Brake Switch works, then the Front Brake Switch is being held in --- If it then does not light the Brake Light when the lever is pulled, I am assuming the button of the switch is not releasing at that time (when the lever is pulled)...
Check the switch positioning to be sure it is not binding the switch button and keeping it from being released when the lever is pulled...
Old 20th May 2019
Okay so I open it back up and found out it was pressing against the side thus making it stick in when putting it all together. The wires are pressing against the switch top/side. I don't think this is the stock handle bar controls or handlebars for that matter. I'll have to make some kind of shim block to keep it in place.
Thank you everyone who help me figure this frustrating issue out you guys really are awesome! I know I'm going to have to replace the whole front control system soon with the right setup. From what i can tell it can run a lot and even more if i have someone else do it.
I have a lot of respect for this place, thank you guys again.
Old 20th May 2019
You are at the right place to save money and increase your knowledge about YOUR bike... If you are even somewhat mechanical (and willing), most projects on a Sportster are able to be self-accomplished... This forum has plenty of hands-on riders who can give advice and help resolve problems...
When you are ready to replace the bars & controls, post up another thread... That will give folks a chance to see what you are up to...
