0 compression problems
Last Post: Sadsack
0 900 dual carb front head
Last Post: SportyHD
0 2 into 1 exhaust build
Last Post: Eddie Lives On
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
0 08 Nightster No Start
Last Post: 1977XLH
Last Post: jammantoo
0 A Day in the Life...
0 Should I buy a Sportster??
Last Post: geekonabike
0 Project Strociek
Last Post: Animal611
Last Post: VaFish
0 '89 Sportster 1200 Chopper
Last Post: deuce460
0 02 sensor query
Last Post: stephenw
Last Post: deuce460
Old 5th December 2018
Gaz907's Avatar
Gaz907 Gaz907 is offline
Sportster/Buell Model: xl883n iron
Sportster/Buell Year: 2014
Gaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud ofGaz907 has much to be proud of
Originally Posted by Tucsonmax1 View Post
I know what the code is. Actually I also had a U100 in mine as well. Dealer said NPF. Bring it back if it happens again.
The fault was an easy fix, connecting block under the tank from the right hand control module was not fully seated, took 5 minutes at the dealers and the technician even took me into the workshop to show me. If yours does it again might be worth a look.
