0 compression problems
Last Post: Sadsack
0 900 dual carb front head
Last Post: SportyHD
0 2 into 1 exhaust build
Last Post: Eddie Lives On
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
0 08 Nightster No Start
Last Post: 1977XLH
Last Post: jammantoo
0 A Day in the Life...
0 Should I buy a Sportster??
Last Post: geekonabike
0 Project Strociek
Last Post: Animal611
Last Post: VaFish
0 '89 Sportster 1200 Chopper
Last Post: deuce460
0 02 sensor query
Last Post: stephenw
Last Post: deuce460
Old 5th December 2018
tamaro tamaro is offline
Sportster/Buell Model: 883
tamaro is an unknown quantity at this point
Thanks! I Still need to find that harness for the turn signal wires, don’t see the skinny adapter (in album on #9) fitting into the wider harness that’s stock on the Sportster. Can’t find one anywhere.
sportsterdoc's Avatar
Not sure what you mean, but turns plug into the stock taillight assembly.
Old 6th December 2018
I’m experiencing difficulty finding what I need to connect the turn signal wires to the assembly, there’s no plastic housing like the one pictured in the album. I have an open housing for turn signals, and 2 bare turn signal wires without a way to connect.
The thin adapters pictured here don’t fit into the wide housing in the same photo.
http://imgur.com/a/EvCgz0W
If you want to keep wiring as stock as possible, then research connectors or purchase them from H-D.
Or you can simply splice them:
You can twist, solder and shrink tube or even use butt splices.
Have you figured out color to color?
HD said they only sell the connectors with entire light kits, so I’ll follow your advice, thanks!
As you said, seems like the 2 yellows are L/R turn signal, just gotta figure out where to connect them
Factory wire colors are in post 7.
No schematic with the new unit?
If not, do you have a link to it?
A VOM or even a simple continuity light should help you test, as needed.
Oh, yes! I just copied your notes on the wire colors from #7, so I’ll connect to the brown and violet wires
The new unit is an eBay third party combo light without schematics, but I found a similar one online with a matching diagram
Black- ground
Red- brake
Green- running
Yellowx2 left and right turn output
Should I
1) replace the wires from the current connection (pictured) with the new matching wires, and only splice the two turn signal wires to the now empty housing
or 2) splice all new wires to the open housing?
Good
You may want to verify before connecting fully
