0 compression problems
Last Post: Sadsack
0 900 dual carb front head
Last Post: SportyHD
0 2 into 1 exhaust build
Last Post: Eddie Lives On
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
0 08 Nightster No Start
Last Post: 1977XLH
Last Post: jammantoo
0 A Day in the Life...
0 Should I buy a Sportster??
Last Post: geekonabike
0 Project Strociek
Last Post: Animal611
Last Post: VaFish
0 '89 Sportster 1200 Chopper
Last Post: deuce460
0 02 sensor query
Last Post: stephenw
Last Post: deuce460
Old 5th December 2018
RREAPER RREAPER is offline
Sportster/Buell Model: Sportster XL1200C
RREAPER is an unknown quantity at this point
Default Rear cylinder popping
So ran into a problem with the bike, just finished doing a little overhaul. So bike was a barn find and I got it running and rode for about a week no problem. Then yesterday I went to start it and pretty soon it started popping and spitting blue flames out the rear pipe. Thinking maybe it was too rich I let off the choke and it stalls. So I opened up the carb bowl to look at the jets and they are clean. Then I open up the throttle and to my surprise there's a slimely oil or gas looking varnish on the manifold side of the carb. So I take the carb off and see that it's all over the manifold too and even the valves too. Whole ignition system is brand new ultima module, coil with msd wire and new plugs. The breather bolts were also spitting up some oil into the k&n slip on air filter. Bikes sitting with rear rockers off right now, thinking maybe bad gaskets? Valve seals? Trying to figure out how to load the pictures, bikes a 01 1200 custom
https://paste.pics/0d29d118eb196f60f6a07fbef1ef645d
https://paste.pics/862ceb16753d0af2b7a10f4acfd96f5d
https://paste.pics/7d219d3f042c636bda48bfe31b50d131
sportsterdoc's Avatar
Could not get third photo to load
1. Is fuel fresh?
2. Is oil fresh?
3. Static timing on Ultima mid-range?
4. Stock exhaust?
5. Full compression?
6. Stock vacuum operated petcock? If so, is diaphragm intact?
Fuel is new, oil is fairly new maybe 2 months. It was static timed and ran fine before this. Stock pipes and yes compression is good. Has manual petcock with the vacuum.
With a vacuum operated petcock, check the diaphragm for cracks or pinholes, which will draw fuel into the carb.
Old 6th December 2018
Diaphragm looks good, nothing visible. Put a flashlight to it and no light poked through. It slides up and down smoothly. I took off the manifold and looks like it's in the chambers also, comes right off with carb cleaner, so I'm guessing it fuel related not oil? Why would oil be coming from the breathers though?
harley506d's Avatar
Sportster/Buell Model: 1200c
Oil from the breathers is a common complaint, especially if the oil tank is slightly overfilled, loads of info on here about it.
Best to route the breathers outside of the airbox.
Not the CV40 carb slide diaphragm, the petcock diaphragm.
...not that it could not be a breather issue.
Old 7th December 2018
Sorry just caught the typo in my original reply, it's a manual peacock, without the diaphragm. The vacuum is capped off.
I wondered about the wording and should have asked for clarification.
Regarding harley506d's post: How full is the oil tank?
Both my 2003 and 2002 preferred the oil level to be mid-point on the dipstick...if not, it would "self-level", as my right pant leg could testify.
