0 compression problems
Last Post: Sadsack
0 900 dual carb front head
Last Post: SportyHD
0 2 into 1 exhaust build
Last Post: Eddie Lives On
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
0 08 Nightster No Start
Last Post: 1977XLH
Last Post: jammantoo
0 A Day in the Life...
0 Should I buy a Sportster??
Last Post: geekonabike
0 Project Strociek
Last Post: Animal611
Last Post: VaFish
0 '89 Sportster 1200 Chopper
Last Post: deuce460
0 02 sensor query
Last Post: stephenw
Last Post: deuce460
  #51
Old 6th December 2018
since an amp meter is in series with the current, it is polarity sensitive and if in backwards, will give the negative reading.
mr. doo, i was not intending to place an existing regulator in the box, it would have to be built, the actual circuits are small even in a off the shelf potted unit. the main current carrying semi-conductors would have been heat sinked to the rear plate.
too true too true mr. folkie. thanks for the good reminder to avoid that goof.
Carboncore Carboncore is offline
Sportster/Buell Year: 1966
Carboncore will become famous soon enoughCarboncore will become famous soon enoughCarboncore will become famous soon enoughCarboncore will become famous soon enoughCarboncore will become famous soon enoughCarboncore will become famous soon enoughCarboncore will become famous soon enough
Bypassed the fuse between the key and battery. Still the same. Bustert that could have been the case with the ammeter. I was using an old unit I had on the shelf. When I hooked it up it did not have any polarity markings on the case. I am out of ideas. To the shop and, I will post as soon as I get this figures out. Thank you to all.
I will load pictures just so everyone can see what I am working on and maybe it might spark something.
Old 9th December 2018
this has my attention,but I see size differences.my electronic regulator mounts on the end of my generator and is close to the same diameter.my 12 v Bosch regulators were maybe half that size?
buster I found an old mechanical regulator.it's approx.3''x2-1/2''.does this seem doable?
Old 12th December 2018
Had to buy a analog voltmeter because the one I purchased off of eBay would not work. Of course and, it was a hundred bucks. Figures. I went to Lowes and purchased one off the shelf. My bike reads a stable just below 14 volts while running and 12.8 with the new battery not running. Gassed it to over 2500 and regulator was working regulating at 14 volts. The 1970 XLCH would not give a stable reading after repairs with a digital multimeter. Although I did get accurate readings with my digital multimeter on my 1979 XLH and my 1966 XLH. It was erratic and, the numbers were jumping all over the place with the 1970 XLCH. Have a 50 mile ride planned for Friday.Hope all goes well but I find it hard to believe that for whatever reason the quality digital meter could not read the XLCH. I will update the post after the ride. Thanks to all.
