0 compression problems
Last Post: Sadsack
0 900 dual carb front head
Last Post: SportyHD
0 2 into 1 exhaust build
Last Post: Eddie Lives On
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
0 08 Nightster No Start
Last Post: 1977XLH
Last Post: jammantoo
0 A Day in the Life...
0 Should I buy a Sportster??
Last Post: geekonabike
0 Project Strociek
Last Post: Animal611
Last Post: VaFish
0 '89 Sportster 1200 Chopper
Last Post: deuce460
0 02 sensor query
Last Post: stephenw
Last Post: deuce460
Old 24th November 2018
denguy denguy is offline
Sportster/Buell Model: 1200
denguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant futuredenguy has a brilliant future
That plug pic is a reminder that plugs can rust through and snap off.
Skuzeee's Avatar
Skuzeee Skuzeee is online now
Sportster/Buell Model: Xl1200c
Skuzeee has disabled reputation
Some of us have found that those issues disappear if you keep the engine in the 5,000-7,000 r.p.m. range, just saying.
Its not the destination, but the road to get there that's my issue
Sent from my SM-G920V using Tapatalk
Old 17th January 2019
Nrg2brn Nrg2brn is offline
Nrg2brn is an unknown quantity at this point
My 2018 does that. My 2016 did not. The techs at the dealer think im insane. Thanks for posting.
Sent from my SM-G950U using Tapatalk
harley506d's Avatar
Sportster/Buell Model: 1200c
May sound a little off the wall, but try setting the carb exactly as in Sportsterpedia.
Especially regarding the throttle plate.
If like me you have changed grips a few times (3 for me) and then re-adjusted the cables at the throttle end thinking all is good.
Then a few days later think the bikes tick over is not quite right, so adjust it a little and while there tweak the mixture screw. After a few times of doing this you also realize the mixture screw is not doing a great deal but set it where you think it sounds ok.
I was also having vibration at low/cruising speed and actually thought the new harder engine mounts were the problem.
I then read the carb article properly and adjusted it as per.
What a difference, all vib's gone, engine so sweet and mixture screw actually working.
So for me, it was just a fueling problem. Worth a check.
