15th November 2019
Posts: 308 Sportster/Buell Model: sportster xlc Sportster/Buell Year: 2005 Sportster/Buell Model #2: xlh 1200 c Sportster/Buell Year #2: 2005 Other Motorcycle Model: Triumph Kawasaki Other Motorcycle Year: 2018
Derby cover
hi lads, can i ask a silly question which side of bike is the Derby Cover ??
don't think there's such a thing on my other bikes,
thanks
15th November 2019
Posts: 3,046 Sportster/Buell Model: 1200/1250C Sportster/Buell Year: 05
Left. On the primary cover
16th November 2019
Posts: 250 Sportster/Buell Model: Hugger Sportster/Buell Year: 2002 Other Motorcycle Model: Panhead Other Motorcycle Year: 1961
Look up a picture of a clutch cover on pre-'65 panhead or knucklehead and you will see that the cover resembled a Derby hat. Internet wisdom is that the resemblance started the nickname "Derby cover", which now is synonymous with "clutch cover".
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
16th November 2019
Posts: 1,755 Sportster/Buell Model: 1200c Sportster/Buell Year: 2005
Derby cover screws are T27 Torx if recall. Golden rule with Torx is to always try the next size up, just in case! The cover O ring can be re-used and you might need a few small blobs of blue Hylomar to help hold it in place in its groove.
Read this before you start.
http://sportsterpedia.com/doku.php/t...vo:priclutch01
16th November 2019
Posts: 281 Sportster/Buell Model: xl 1200c custom Sportster/Buell Year: 2006
16th November 2019
That Ebay cover shows the classic "Panhead Emergency Brake" damage that happens when you go down into a slide on the primary side! I still have one just like that in the garage from when I did.
