0 hello and help!
0 battery drain
0 Headlight - What are you using ? - '74 XLH
0 newbie
Last Post: kkbii
0 Ignition coil rating ?
Last Post: 45Brit
0 Happy Birthday Joebobber
Last Post: joes95bobber
0 Breather in cam cover 1985
Last Post: Bow only
0 Do people notice your bike?
Last Post: 83XLX
0 New to us
11 Ss carburetor
0 Battery Voltage Question
Last Post: canoli
0 Happy Birthday Crusty!!!
0 My 1250 to 1275 build
0 An Ohio Meet 'N' Eat
Last Post: Jcolleyoh
Last Post: hhugger
0 2001 motor in 1987 frame?
Last Post: Jason's Sporty
0 Dry clutch to wet clutch
0 1969 Sportster 50th Anniversary T-Shirts
Last Post: Kingrabbit
0 Suggestions on no start
Last Post: mickey t
DaddyJay, sixshooter (72), cartoad2001 (70), Dirty Ernie (64), ncpickman (58), bri1200c (56), pquirk (53), GOTWA (50), gremlinsteve (50), lbowles2 (48), Guess (40), rnaway22es, landon283 (31)
Old 30th July 2019
canoli's Avatar
canoli canoli is online now
Great thanks Wedge - I bought a new screw anyway b/c the end of the one I have looks pretty beat up - whoever cross-threaded it must've really forced it - though like you said I don't know how a steel screw got stripped going into an aluminum cover.
Thanks again you guys I appreciate your help.
