0 hello and help!
0 battery drain
0 Headlight - What are you using ? - '74 XLH
0 newbie
Last Post: kkbii
0 Ignition coil rating ?
Last Post: 45Brit
0 Happy Birthday Joebobber
Last Post: joes95bobber
0 Breather in cam cover 1985
Last Post: Bow only
0 Do people notice your bike?
Last Post: 83XLX
0 New to us
11 Ss carburetor
0 Battery Voltage Question
Last Post: canoli
0 Happy Birthday Crusty!!!
0 My 1250 to 1275 build
0 An Ohio Meet 'N' Eat
Last Post: Jcolleyoh
Last Post: hhugger
0 2001 motor in 1987 frame?
Last Post: Jason's Sporty
0 Dry clutch to wet clutch
0 1969 Sportster 50th Anniversary T-Shirts
Last Post: Kingrabbit
0 Suggestions on no start
Last Post: mickey t
DaddyJay, sixshooter (72), cartoad2001 (70), Dirty Ernie (64), ncpickman (58), bri1200c (56), pquirk (53), GOTWA (50), gremlinsteve (50), lbowles2 (48), Guess (40), rnaway22es, landon283 (31)
shanneba shanneba is offline
Originally Posted by shipwreck View Post
Ok. Scratching my head here....looking for that thread that went super in-depth on the powervision, can't find the darned thing though. anyone be able to assist with a link?
My thinking is that I need to do some tuning on sunday.
There is this PV thread (older)
http://xlforum.net/forums/showthread.php?t=1199290
This one is newer (started in 2015)
http://xlforum.net/forums/showthread.php?t=1932673
34-38 at 2250 and 50 MAP seems a little advanced to me.
I don't hit 38 degrees at 50 map until about 4500 rpms.
I looked at many of the HD stage 1 tunes, it seems to me they improved the timing as they changed to the 374 and 414 software levels. Those software levels are lambda based tunes and also have a "closed loop" AFR range of around 14.2- 15.0.
I downloaded the HD Pro Street tuner software to view the tunes.
You can use all 1's for the VCI serial number.
I run closed loop at all MAPS 80 and under up to 4500 rpms.
(I will at a MAP over 80 (in open loop) at most TPS of over ~30 %)
I do have the AFR Bias set a little richer at 80 and 100 MAP and above 4500 rpms.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Are you monitoring (logging) knock? The software won't pull timing but it will tell you there's knock.
I have a 2013 Sportster, the ION sense was not available then.
