0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 fork seal
0 First XL - XLCH or XLS?
Last Post: JB in NC
0 New from the cold north...
0 83 Sportster basket case
Last Post: joe s
0 Clutch Slipping at higher RPM
0 Jetting 42 mikuni
Last Post: wrkdWS6
0 charging
0 Broke Down and Ordered an Optima Ignition Kit
0 Helmets Please...
Last Post: gusm2
0 Old man walks back into a forum..
Last Post: Phillober
0 forward controls for an 81
0 Allegheny 2023
Last Post: wardie
0 72 xlch is overcharging... bosch mechanical reg
Last Post: rocketnorton
0 R.I.P. Tina Turner
Last Post: MDT
0 Axle-grease question
0 Disappointed with Eastern shift forks
Last Post: davixlrtt
0 Highway Pegs recommendation
Last Post: Yochstein
0 Passenger backrest for 07 883?
Last Post: Mike1nw
0 Registration question
0 "S" model specific Q&A
Last Post: Model H
0 More advice.... (2007 Roadster Seat On 2011 Superlow?)
Last Post: wiltybob
0 .551 Cams in an EFI 1200
Old 5th January 2023
Turbid Turbid is offline
Sportster/Buell Model: XL883
Turbid is an unknown quantity at this point
Default I have a couple questions regarding a 2004 883 Custom
I just bought the bike in the picture and have a few changes I would like to make but I am unclear about the differences between the 04/05 and everything that follows when it comes to the exhaust system.
The first change I want to make is to swap the forward controls for mid controls, but I was told by the seller that I would have to change the exhaust in order to do that. Looking at the picture is that true?
Most importantly I was also told that buying a new exhaust system for the bike would be a pain in the ass because 04/05 (Rubber mount, carb) bike require different exhaust because it's a rubber mount, but wouldn't that mean that all rubber mount sportsters from 04 forward would use the same system? I don't see why carb vs EFI would matter.
This is the bike.
BKB's Avatar
BKB BKB is offline
'04 thru about '09 the exhausts are identical. You don't need to change anything to swap the foot controls, either. Straight up, bolt on trade. Your PO may be correct about that exhaust that's on there needing to be changed, tho, to fit the mid controls. Some of the after-market pipes are not compatable with both mids & forwards. I'm only familiar with the stock pipe configuration as I like the look of the tapered mufflers.
Old 6th January 2023
XL Ed's Avatar
XL Ed XL Ed is offline
That looks like a Bassani. I don't remember anything about them not fitting my 04 with mid controls.
Thank you for the hint on the exhaust make. I think these are them.
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Those pipes don't fit with mid controls.
04/07 1275 BFH heads Darkhorse XB crank .600 cams S&S 1.725 rockers S&S precision lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Old 7th January 2023
XL Ed's Avatar
There you go. I stand corrected.
Old 3rd February 2023
roachhill roachhill is offline
Other Motorcycle Model: Ducati Monster
Other Motorcycle Year: 1995
roachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud of
EFI pipes just need to have plugs put in the O2 sensor ports. I think Lowbrow and TC Bros both sell the plugs.
ParrotHead's Avatar
Other Motorcycle Year: 1974
This is the bike.
In 2007 EFI was introduced, so 2004-2006 stock exhaust would not have O2 sensors and be a direct swap.
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
Old 5th February 2023
Andy56 Andy56 is offline
Andy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond repute
To directly answer the question the EFI bikes have O2 sensors in the exhaust to monitor fuel burn and the system can tweak the mixture a bit up and down to compensate. Your bike not being EFI doesn't need the O2 sensors but the exhaust mount to a bracket affixed to the engine so it can all move as one lump.
Using SuperTrapp as an example they make 2-in-1 labelled for 2004 to 2013. They supply bungs to put in the O2 ports.
They also claim they will fit bikes with forwards and mid controls.
