0 fork seal
Last Post: g5guzzi
0 New from the cold north...
0 First XL - XLCH or XLS?
0 83 Sportster basket case
Last Post: joe s
Last Post: SaddleBronc
0 Clutch Slipping at higher RPM
0 Jetting 42 mikuni
Last Post: wrkdWS6
0 charging
0 Broke Down and Ordered an Optima Ignition Kit
0 Helmets Please...
Last Post: gusm2
0 Old man walks back into a forum..
Last Post: Phillober
0 forward controls for an 81
0 Allegheny 2023
Last Post: wardie
0 72 xlch is overcharging... bosch mechanical reg
Last Post: rocketnorton
0 R.I.P. Tina Turner
Last Post: MDT
0 Axle-grease question
0 Disappointed with Eastern shift forks
Last Post: davixlrtt
0 Highway Pegs recommendation
Last Post: Yochstein
0 Passenger backrest for 07 883?
Last Post: Mike1nw
0 Registration question
0 "S" model specific Q&A
Last Post: Model H
0 More advice.... (2007 Roadster Seat On 2011 Superlow?)
Last Post: wiltybob
0 .551 Cams in an EFI 1200
Old 6th February 2023
conkey conkey is offline
Sportster/Buell Year: 1974
conkey is an unknown quantity at this point
Default Vm38 o ring
Vm38 o ring
Quick query if I can team.
Is it standard practice to fit the large o ring on the manifold side of the carby..when fitting to the branch manifold rubber adaptor.? Hope that make sense?
Seems to create air leak when I do..ok without?
Many thanks
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 1973
Originally Posted by conkey View Post
Vm38 o ring
Many thanks
The Branch manifold for 74 has two stock oring connections to the heads and one larger rubber adapter to the carb. That rubber adapter has two band clamps. Is that what you have?
If you are saying there is an additional o ring inside the adapter remove it.
a lot of people will roll the ring onto the manifold, fit the alignment and roll the the ring into the groove instead of fiddling both operations.
a big issue is usually with the head side especially so when the little lip extension is broken.
when i do mine, i will use glass oven tape over the o-ring, once heated, it will seal the joint, BUT, a bear to remove.
joe s joe s is offline
Sportster/Buell Year: 72
Sportster/Buell Year #2: 71
Other Motorcycle Model: Five Harleys
joe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud of
Have you tried rubber electrical tape (friction tape)? It does a great job backing up the o-ring and easily removed later. Not vinyl electrical tape.
Old 7th February 2023
electric tape will work but heat and fuel are its worst enemies. you will have a big goo on your hands. oven tape takes the heat and being glass fiber, fuel does not touch it. the big problem is you have to cut the tape off and then the adhesive has to come off with a solvent, but once on there, it is there.
Old 8th February 2023
sungod's Avatar
Vm38 o ring
Many thanks
The fit should be tight. If the adapter is in good shape you should not need any wraps. Make sure you have the right size adapter. Also use the support between the a/c and the lifter pad. You can always lube the adapter with diluted liquid dish soap for an easier install.
