0 Trackday Sportster
0 POLL: Vance and Hines
Last Post: Darkseacret
0 1970 sporty, hard to crank
Last Post: doc martin
0 Jutland 05-31-16
Last Post: Akdawg
Last Post: r4fthrs
0 1965 Ironhead in CT
Last Post: forqueue
6 Is Your SPORTSTER...
Last Post: wandrur
0 It's Flame__'s Birthday!
Last Post: 83XLX
0 Hello from NY
Last Post: hexnut
0 THE Trainspotting Thread
0 And so it begins......
Last Post: Rossline
Last Post: Blowupster
0 Mag wheel corrosion
Last Post: shaymus
0 Forum problems???
Old 11th October 2018
cmerr cmerr is offline
cmerr is an unknown quantity at this point
Default newer rear fender on older sportster
Have to opportunity to purchase a newer rear shorter rear fender off a later model sportster (believe it was on a 48) and id like to put it on my 1998 sportster....anyone know if there will be fittment issues? Thanks in advance for your input.
Old 12th October 2018
Folkie Folkie is online now
Yes there will be fitment issues, since the rubbermount rear fenders are wider than the solidmount ones.
Any idea how much wider? Can you elaborate please? Thanks
I don't know how much wider, because I don't know how wide a solidmount fender is. However, the rubbermount fender is about 8¼" wide, maybe a bit more. That won't fit between your fender supports, will it?
They're wider because the rubbermounts have wider rear tyres: 150mm wide instead of 130mm.
Subscribing Biker
Measure the distance between your fender struts and this will tell you how wide of a fender will fit on your bike. How deep will be determined by the size of rim/tire you run.
