0 Trackday Sportster
0 POLL: Vance and Hines
Last Post: Darkseacret
0 1970 sporty, hard to crank
Last Post: doc martin
0 Jutland 05-31-16
Last Post: Akdawg
Last Post: r4fthrs
0 1965 Ironhead in CT
Last Post: forqueue
6 Is Your SPORTSTER...
Last Post: wandrur
0 It's Flame__'s Birthday!
Last Post: 83XLX
0 Hello from NY
Last Post: hexnut
0 THE Trainspotting Thread
0 And so it begins......
Last Post: Rossline
Last Post: Blowupster
0 Mag wheel corrosion
Last Post: shaymus
0 Forum problems???
Old 16th October 2018
> ...my light is reading threw the coil to ground. Is this correct??
Yes. The coil is a path to ground; it needs to be disconnected when using a test light or multi-meter to set static timing.
Other points:
Narrow cam lobe must be located counterclockwise from the cam follower.
Front cylinder must be on compression stroke when the flywheel mark is centered in the observation hole.
See pp 5F-13 on, in the FSM for the gory details.
If you want to do something, you’ll find a way. If you don’t, you’ll find an excuse.
Old 17th October 2018
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Dave (Morris Magnetos) sells a "Buzz Box" for use with magnetos. Worth every penny.
Easy and simple to use it isn't simply a light and a battery - it measures induction.
A led light for us deaf bas&ards and a buzzer for us blind bas&ards.
It can be used to check battery and coil systems and relays as well.
For $80 you too can set your points correctly. Exactly.
