0 Trackday Sportster
0 POLL: Vance and Hines
Last Post: Darkseacret
0 1970 sporty, hard to crank
Last Post: doc martin
0 Jutland 05-31-16
Last Post: Akdawg
Last Post: r4fthrs
0 1965 Ironhead in CT
Last Post: forqueue
6 Is Your SPORTSTER...
Last Post: wandrur
0 It's Flame__'s Birthday!
Last Post: 83XLX
0 Hello from NY
Last Post: hexnut
0 THE Trainspotting Thread
0 And so it begins......
Last Post: Rossline
Last Post: Blowupster
0 Mag wheel corrosion
Last Post: shaymus
0 Forum problems???
  #81
Old 18th November 2017
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
2013 XL1200 Sportster owned by a valued HAMMER PERFORMANCE customer, equipped as follows.
Comments: This is effectively our 110+hp 883 conversion package as applied to a 1200, with one big difference: it still has the stock, unmodified throttle body. In our testing, a simple low-cost porting service on the stock throttle body is good for about 5 horsepower at this level. We're hoping to get our hands on it and find him some more power.
Click Here to Contact Me
Old 6th May 2018
aswracing's Avatar
1250 and 1275 conversions, done on the same bike with the same set of stock 883 heads, same Patriot exhaust, Powervision tuner, Dynojet dyno, etc.
Same 1250 & 1275 results, as compared to the same bike when it was a stock 883.
Old 10th December 2018
aswracing's Avatar
2007 XL883 equipped as follows:
  • Stock EFI 1200 heads
  • Stock original "W" cams
  • Air Hammer air cleaner (SLEDGE model)
  • Patriot exhaust
  • Dynojet Powervision tuner
  • tested on the same Dynojet 188 dynamometer
Blue: flat top 1275 kit
Red: flat top 1250 kit
Green: stock 1200 cylinders and flat top pistons
Comments: Through the bottom and middle, making the motor bigger adds a lot of torque and power. But as you go higher in rpm, the lines converge, and the big bore kit doesn't bring nearly as much to the party. Also notice how the bigger the motor, the lower the rpm at which the horsepower peaks.
That's typical of a motor that's had it's displacement increased without a corresponding increase in breathing. Making the motor bigger causes the air demand to go up. At low to mid rpm ranges, there's plenty of time to fill the cylinder, so the displacement increase brings a bunch more torque and thus power. But at high rpm, things are happening faster and faster, there's less time to fill the cylinder, and the motor becomes breathing constrained instead of displacement constrained.
So to get a big top side number with a big bore kit, you really need to do breathing mods as well (cams and/or head work).
However, for many people, the bottom to the mid range is more important anyway. So a lot of these kits get installed without cams and/or head work and the owner is perfectly happy with the results.
aswracing's Avatar
Today we tested the 1275 kit with the JACKHAMMER 570 Cams and got the above result.
Details: 2007 XL883 equipped as follows:
  • Patriot exhaust
Blue: flat top Flat Top 1275 kit and JACKHAMMER 570 Cams
Red: stock 1200 cylinders, stock 1200 flat top pistons, and stock "W" cams
These are the only changes between the two pulls, plus the EFI was remapped for each configuration.
aswracing's Avatar
We also tested the porting of the throttle body on this same result:
Blue is the ported throttle body
Red is the stock throttle body
This is result is pretty typical when we port a throttle body at this power level. 105ish hp is right on the cusp of where the stock throttle body starts becoming a significant restriction on the motor. Going up from here, it starts costing pretty significant power and you definitely want to address it.
Folkie Folkie is online now
Just a reminder: posts with dyno charts only; no comments or chat here please. Other posts will be deleted. Comments and questions about the dyno charts posted here can be posted in a separate thread in the Dyno Charts And Results section. Thanks.
