0 Rear Brake Squeal Fixed
0 Primary thread
0 Black Bike Bible
0 Allegheny National Park III
Last Post: sprink
Last Post: paulc
0 Rocker Arm Acorn Nut Torque Problems..
Last Post: Flam
0 Informed reviews!
0 R.I.P.Meat Loaf
Last Post: deguireb
0 my motorcycle trailer (goes down flat, comes back up)
Last Post: adri
0 1980 Shovelhead WideGlide
0 Speedometer
0 weight loss thread
0 Dyno Test Results: W Cams versus D Cams
Last Post: Jonny48
0 2022 Sportsters
Reynoldston (81), showmebandit (68), Hoppy1313 (68), FredrikK (66), Toejam503 (66), YO MUDA (63), Altopass (62), tim 2007xl1200c (55), w9awx (49), 3xtrastout (43)
DR DICK's Avatar
DR DICK DR DICK is offline
DR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond reputeDR DICK has a reputation beyond repute
if you check the 99451-71 parts catalog you will see all the all the exhaust systems available 57-71 except one. that being the factory straight pipes.
D.D._____________________________-o&o____________________________
