0 Xl???
Last Post: SLW210
0 AHDRA Orlando speed world??
Last Post: painterdude923
Last Post: SLW210
0 Replace lifter(s) w/out teardown?
Last Post: canoli
0 Sportsters in movies and TV
Last Post: SLW210
0 TC88A update ?
Last Post: HOG63
0 72 XLCH clutch ball and ramp system
0 Your never too old
0 Tuners
Last Post: Sirrom1
0 Morning default to odometer
Last Post: Eric Von Zipper
Last Post: leon bee
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
Last Post: sportymike02
Last Post: Zip1
0 Ironhead heavy duty cable amps ?
Last Post: Uberstorm
0 Xl for sale
Last Post: jeosbolt
Last Post: chardhin
0 Pawl Carrier Support Bushing ???
oldsporty1 (70), paris15 (62), thesmithiz (62), pajimmyjoe (61), chuckam (57), steve w (51), le_strike (44), Rubicon (38), r3db3ard3d (32), rortiz76 (32)
Old 24th April 2012
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Default Screw Loose's 90" Street Build - aka 2012 Refresh
Well, I've had the bike since August 2006 and put somewhere around 48,000 miles on her. In December of 2006 I had the now infamous "screw loose" moment in the hills of West Virginia and by February 2007 she had been converted to a 1212 with 883 stage 2 heads and 497 cams.
Those of you that have been here long enough will remember (have nightmares about??) the oil consumption threads back in 2007/2008. I was one of the "participants". The top end has been off my bike more times then a stripper spreads her legs in an evening, looking for insight and solutions to stop using oil since the conversion. (Somewhere in there I swapped the 497's for 536 cams.) I've been told the oil consumption issue has been addressed with proper rings, which I had put in. I still use more oil then I care to talk about. But, admittedly my bikes been abused. Also, the Harley shop that originally did my conversion did me no favors (gap rings??). So, there's always been question marks as to what and where the problem was. Ultimately, after obsessing for the first year or so I've continued to put oil in and just ride.
Long beginning to this story...
Now, the bike's been making a bit of a racket. First thought it was just an exhaust leak. Fixed an intake leak. Thought maybe a floating valve or something. Again, I haven't really babied it for those miles. Decided it was time to freshen things up. Had enough miles on her to warrant doing some work. Always wanted 1200 heads. Always longed for a true BIG bore (I chuckle when I see guys refer to 1250 as big bores).
But, I still want this thing to handle an occasional road trip. I have the 1200R now as a second bike and will likely use it for most of my trips. But, ya never know when a hot woman from Australia wants to come over and go on a road trip. So, the bike will need to be "streetable" and reliable. Everyone's definition of these things varies (remember, I've putting a quart or two of oil in at least every 1000 miles ).
The Plan: At this point most decisions are made, but I'm sure there will be some game day decisions.
  • 90" cast iron cylinders.
  • 1200 Heads with either Crush or Sledge head work (I'm currently leaning towards Sledge). 15° squish band and all the normal goodies from Hammer Performance.
  • RS585 Cams
  • Balanced and Carrillo rods for the crankshaft
  • Jims Lifters
  • S&S Roller Rockers
  • Assembled by Hammer Performance
There's a few compromises here. The cast iron even though it weighs a bit more, I want the added strength. The RS585 cams...that's been a tough decision but Hammer Dan and I discussed it at length and I think that's the best compromise. They are also proven performers in this configuration and I didn't want to go over .600 lift. The assembly - as much as I love tooling on my bike, a man must know his limits. You add these parts up and it becomes expensive. Remember - there's a reason for the Screw Loose moniker. So, I decided to have Hammer make sure everything fits together like it should. (I think it was Lenster's build where I saw the grinding on the cam chest that pushed me over the limit! )
A fair warning! This build will likely be the slowest moving on earth. I'm not in any sort of rush at this point. And most of the "juicy" stuff is being done by Hammer Performance.
But, I'd be banned if I didn't include some pictures. Here's removing stuff.
"Before"
Progress:
Took days to get the transmission sprocket off and buying more and more tools until I got it, so I have to include this picture...
Crated and ready to go:
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 24th April 2012
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Oh yeah a 90 inch thumper!!!
Old 24th April 2012
ReddTigger's Avatar
Dam Dan.. Way to go..
So Now I'm like officially Jealous..
States I've Ridden in
71.3 hp 70.8 tq
Old 24th April 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
Figured something like this was coming when I saw the thread about engine shipping . Will be keeping an eye on this one, congrats Dan!
Sent from my BlackBerry 9800 using Tapatalk
Old 24th April 2012
OmegaRunner's Avatar
OmegaRunner OmegaRunner is offline
Sportster/Buell Model: 883/1250 XL
Sportster/Buell Model #2: Blast (wife's bike)
Sportster/Buell Year #2: 2002
OmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really niceOmegaRunner is just really nice
Right-on Dan! I look forward to reading your write up as the project progresses. I dream of doing the same and sending my motor off to a professional. Someday...
Old 24th April 2012
td67mustang's Avatar
td67mustang td67mustang is offline
td67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura about
Well now I'm subscribed! This is gonna be a fun one to watch.
Old 24th April 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Very nice selection of parts and having someone else doing the machine work and wrenching is a cool way to get what you want without having to worry about missing something. The only engine work I ever had done outside was the 454 in my 70SS. Too much $$$ involved to risk messing it up.
Support the forum because the :xlrocks
George
"Peace is that brief glorious moment in history when everybody stands around reloading . "
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Heads w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Hammer Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Energy One Clutch w/ 15% Diaphram, Muller Power Clutch, Basanni Road Rage 2-1 Exhaust w/ 4" Performance Machine Billet Tip. Drag Specialties 8-Bolt Encapsulated Rotor, Cycle Electric Regulator and Stator.
Old 24th April 2012
xlint89's Avatar
xlint89 xlint89 is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 89
xlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura about
Congrats. You're going to love the TQ these big bores make. IMO, all sporties should have at least an 88"
Carillo rods??? Holy smokes, those are pricey!!! are you sure you need them? Are you going to be racing?
Check out EGNBLU 90". He had a crazy good dyno chart. Something like 100 ft lbs at 2000 RPM and stayed there I think until 6000.
He had your exhaust (D&D fatcat) and S&S 600 cams I believe.
Stock............. Isn't that a soup or something?
Old 24th April 2012
Thanks everyone for the words of encouragement. I'm not quite at the point of uber excitement yet as it's still a long road ahead before I'm popping wheelies at will.
No racing, but I want reliability. And they aren't as expensive as I thought they might be (but it's all relative at this point).
I'm VERY familiar with EGNBLU's build. There's no doubt it was the seed that started all this.
You mention dyno numbers. And, I'm sue I'll be asked a bazillion times, so I'll mention...I'm not crazy about comparing dyno sheets. I think they serve a purpose and are a tool. But, it's not something I obsess over. Will I get it dyno'd? I'm sure. Will I share, probably. Numbers I'm shooting for? Conservative 100+/100+. It's more about the miles of smiles!
Old 24th April 2012
Rico 05R's Avatar
JESTER SYNDICATE
With Hammer Dan doing that 90 for you, it will be an ass kicker for sure.
