2 My 1275 Hammer Conversion..
0 su carb question
Last Post: fafcpa
Last Post: DitchTBHSMM
0 New to the Chopper Lyfe
Last Post: TUCCI
Last Post: brixtonanima
0 Too HOT to ride?
Last Post: Billy1200
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
  #561
Old 21st July 2013
Gcram399's Avatar
Gcram399 Gcram399 is offline
Just watched your video. I really never got to see the bike running on the road over the weekend. Bike does sound strong and having all the extra power should make riding the roads we did so much more fun.
George
--Thomas Jefferson
