0 Aluminum patina
0 Where To Get Free Air
0 Has there ever been a 120* vs 90" DD comparison ?
Last Post: Ghostdog
0 Ugh -- looking at bottom end rebuild
0 40 Years
Last Post: Randy_rots
0 82 XLH in Arkaksas
0 New Member
0 Tappet Roller kits questions
Last Post: bill smith
Last Post: Mazdog355
0 Rubbermount Poll
Last Post: JunkyardDog
0 Fatster Project
Last Post: Tonyb65
0 Show me your bike standing next to a sunset...
5 Clutch replacement
9 Transmission Case Wear/Shafts
Last Post: ZachXLCH
0 I was surprised Friday, would appreciate some input.
0 Happy Birthday Shanneba!!!
0 Invalid:
0 Dreaded carb again
0 Happy Birthday Crusty and Joes95bobber!
6 Static Timing: Identifying Wide/Small Cam Lobes
Last Post: 73HEAD
0 head specs
Old 11th August 2019
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
Default First startup
Hey all I just buttoned everything up on my 71 xlch...kicking it over w nothing but a xouple pops...I also had oil spit out my vent tube..is that just extra oil that's in there?I would imagine it would take a bit to kick over it ran when I bought it but just had it sit for a couple months while I did some work on it...nothing major in the motor or trans...new tank fender stuff like that..any tips on what to look for while trying to kick her over again ?
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
Originally Posted by mickey t View Post
...I also had oil spit out my vent tube..is that just extra oil that's in there?...
Yes, most likely
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 12th August 2019
doodah man's Avatar
while it was sitting for a couple of months, did you keep the battery on a tender or get a new battery? if it's the old battery it could just be dead or not enough juice to light it off.
mickey t's Avatar
Well it wasn't on a constant tender...what I did was charge it to full charge..remoced it then charged to full charge again before I tried to kick it....if it shows full charge could it still ne weak to kick it over?
mickey t's Avatar
Good point
Old 13th August 2019
mickey t's Avatar
Hey brother...I believe it was you who steered me in the direction if tje Mikuni vm38...did you say that the idle screw n mix were opposite of S&S?
doodah man's Avatar
The mix screw is backwards from most other carbs, it controls air instead of fuel. So turning it in, closes off air making it richer, and out for leaner/more air.
mickey t's Avatar
Ok thank you
GA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond reputeGA_Ironhead has a reputation beyond repute
Wet sumped... All part of their charm.
http://xlforum.net/forums/showpost.p...8&postcount=40
On the plus side, Americans are learning the Greek alphabet.
IronMick's Avatar
To be good, a battery must satisfy all three conditions...
  • it must take a charge
  • it must hold the charge over time
  • it must hold the charge under load
So
  1. give it a full charge,
  2. disconnect the charger and let it sit for 24 hours,
  3. attach a voltmeter, watch the voltmeter while cranking the engine with the starter button. The reading should not drop below 10 or 11 [people have different opinions here] volts.
If you have a kick only go to Princess Auto or Harbor Freight and buy a battery load tester. They are not overly expensive. Every IronHead owner should have one. Saves those stupid trips out to get it load tested.
