0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 Aluminum patina
Last Post: rocketnorton
0 Where To Get Free Air
0 Has there ever been a 120* vs 90" DD comparison ?
Last Post: Ghostdog
0 Ugh -- looking at bottom end rebuild
0 40 Years
Last Post: Randy_rots
0 82 XLH in Arkaksas
0 New Member
0 Tappet Roller kits questions
Last Post: bill smith
0 05 1200R cylinder oil leak and clacking
0 Show us the different versions of your bike!!
Last Post: Mazdog355
0 Rubbermount Poll
Last Post: JunkyardDog
0 Fatster Project
Last Post: Tonyb65
0 Show me your bike standing next to a sunset...
5 Clutch replacement
9 Transmission Case Wear/Shafts
Last Post: ZachXLCH
0 I was surprised Friday, would appreciate some input.
0 Happy Birthday Shanneba!!!
0 Invalid:
0 Dreaded carb again
6 Static Timing: Identifying Wide/Small Cam Lobes
Last Post: 73HEAD
Old 12th August 2019
Put a pan under the vent to catch the oil it will puke, this is normal after extended storage.
It will turn over slow because of the oil that has collected in the cases. It will crank slow also because of the accumulated oil.
Jump it off a car so you don't damage the battery from extended cranking. I use some spray carb cleaner to help it start.
It will stall and not want to idle untill it runs long enough to clear the oil from the cases. Do not add oil to the tank until it has run for a while as it will need the room for the oil that has collected in the motor.
Make sure that the fuel is fresh.
On the plus side, Americans are learning the Greek alphabet.
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
Will do thank you
Sent from my LM-X210APM using Tapatalk
mickey t's Avatar
Yes I went n got fresh premium to put in there...put a new tank on there so its got nothing but fresh gas
Old 13th August 2019
rokytnji's Avatar
rokytnji rokytnji is online now
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Now time to go buy beers. Round up some bodies. Find a slope.
Squirt gas in da carb throat. Old mustard bottle works for me.
Roll that sucka down hill making sure petcock is on, jump start with bodies, and see what happens next.
I'd worry about the kicker later.
Traveled to
mickey t's Avatar
RAIDER0372 RAIDER0372 is offline
Sportster/Buell Model: NIGHTSTER
RAIDER0372 is an unknown quantity at this point
RIDE HARD.
GOD SPEED.
mickey t's Avatar
Originally Posted by doodah man View Post
while it was sitting for a couple of months, did you keep the battery on a tender or get a new battery? if it's the old battery it could just be dead or not enough juice to light it off.
Hey brother...I believe it was you who steered me in the direction if tje Mikuni vm38...did you say that the idle screw n mix were opposite of S&S?
doodah man's Avatar
The mix screw is backwards from most other carbs, it controls air instead of fuel. So turning it in, closes off air making it richer, and out for leaner/more air.
mickey t's Avatar
Ok thank you
