Last Post: gravydog
0 XLCH Crazy voltage spike
Last Post: Seeny
0 Daniel Boone controls
Last Post: Medyo Bastos
Last Post: MonkeyMadness
0 DK Custom '19 Summer Adv. Riding to where Titanic Sank -Newfoundland Island & More
Last Post: rubine
0 Carburetor opinions
0 Hi from North Wales, UK
0 Fitment between 2005 & 2006
0 Wiring Diagram in autocad
0 1960 XLCH in the UK
Last Post: lynnx
0 Wet Sump Ifo, fix and tools
0 Change jets without removing carb?
0 Need help desperately rewiring the front of my bike
0 IT"S "dodgetrucken"s BIRTHDAY!!!
0 Mild 1250 build thoughts?
Last Post: Ghostdog
0 rotating engine by hand
Last Post: xlerate
0 Talking dog
Last Post: Boil1337
0 Gerbing Heated gear sale
Last Post: Cindy Dietz
0 HD by Italian east coast
6 SPORTY BOBBER PICTURES
Last Post: Lone Rider
0 foo foo foo foo
0 Hello from Az
Last Post: Fiachra
Old 8th March 2019
jimmyess333's Avatar
jimmyess333 jimmyess333 is offline
Sportster/Buell Model: none
Sportster/Buell Year: 0
jimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud ofjimmyess333 has much to be proud of
Default Has anyone tried Harley's new "Heavy synthetic gear oil 80w-140"?
How was your experience?
Old 8th March 2019
Kbetts's Avatar
Kbetts Kbetts is offline
Other Motorcycle Model: Suzuki DL650ADV
Kbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond repute
Sounds interesting...
Product Details
TESTED-CERTIFIED for use in Harley-Davidson® transmission and primary chaincase applications. Exclusively engineered for Harley-Davidson® Motorcycles, this Heavy Synthetic Gear Oil is intended for use in extreme temperature environments (desert heat or cold weather), frequent two-up riding and heavy load riding applications.
Dual viscosity (SAE 80W-140), heavy weight gear & primary oil was developed with proprietary additives and pure synthetic base stock so it flows better at cold start-up then in high temperatures viscosity behaves like a 140 weight oil to provide maximum
Formulated to maintain the proper coefficient of friction for clutch operation and provide superior lubrication for the primary chain drive
Provides specialized lubricity for the anti-wear requirements of transmission gears across a wider temperature range than mineral based oil
Approved by Harley-Davidson for use in all stages of transmission and primary chaincase life
Not for use in the crankcase as a motor oil
Fitment:
All H-D® Transmissions and the following primary chaincase applications: ‘71-later XL, ’83-'84 XR1000, '08-'13 XR, and '84-later Big Twin models with wet-type diaphram spring clutch. Not for use in '02-'17 VRSC™ or '15-later XG models.
Old 17th March 2019
chris allen chris allen is offline
Sportster/Buell Model: 1200 iron
Sportster/Buell Year: 2018
chris allen is an unknown quantity at this point
I haven't been very happy with the shifting noise,quality and difficulty finding neutral on my 2018 1200 iron.I chalked it up the newness of the bike expecting it to get better in time but it hasn't gotten much better.After reading about this new synthetic 80w140 I decided to give it a try. I'm glad I did because it literally fixed all the complaints I mentioned.It shifts smoother,quieter and finding neutral is 100% better I'd recommend this oil,it's worth what it costs.
Old 18th March 2019
ChinCactus's Avatar
I have not tried the Harley version but just used Amsoil Synthetic Transmission fluid in my Road King. So far I'm impressed! It has quieted the clunky shift noise!
Trailhawk750 Trailhawk750 is offline
Sportster/Buell Year: 2019
Trailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of lightTrailhawk750 is a glorious beacon of light
I run it in my 1200C. Made finding neutral easier, but didn't notice a difference otherwise. Didn't expect one either, just like the improved protection over 20/50 in the desert
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Not the HD brand but Spectro Heavy Duty Platinum STL 75W140 .
Worked great but switched to their Heavy Duty Primary & Chaincase Oil which is an SAE85 when I went with the E1 clutch where synthetics aren't recomended.
