Last Post: gravydog
0 XLCH Crazy voltage spike
Last Post: Seeny
0 Daniel Boone controls
Last Post: Medyo Bastos
Last Post: MonkeyMadness
0 DK Custom '19 Summer Adv. Riding to where Titanic Sank -Newfoundland Island & More
Last Post: rubine
0 Carburetor opinions
0 Hi from North Wales, UK
0 Fitment between 2005 & 2006
0 Wiring Diagram in autocad
0 1960 XLCH in the UK
Last Post: lynnx
0 Wet Sump Ifo, fix and tools
0 Change jets without removing carb?
0 Need help desperately rewiring the front of my bike
0 IT"S "dodgetrucken"s BIRTHDAY!!!
0 Mild 1250 build thoughts?
Last Post: Ghostdog
0 rotating engine by hand
Last Post: xlerate
0 Talking dog
Last Post: Boil1337
0 Gerbing Heated gear sale
Last Post: Cindy Dietz
0 HD by Italian east coast
6 SPORTY BOBBER PICTURES
Last Post: Lone Rider
0 foo foo foo foo
0 Hello from Az
Last Post: Fiachra
oil leak
randy3934's Avatar
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
I magnified the pic, I see nothing wrong, little bugger on the end of snap ring but in correctly and fine, when installing seal the tricky part is to install seal and screws loose, install sprocket, then snug a couple of the screws on the seal retainer, small needle nose pliers work for this, remove sprocket and blue locktite each of the screws one at a time. reinstall sprocket, bead of silicone around spline and sprocket, install sprocket nut keeper and nut, put bike in gear, hold brake and tighten nut, fold ear on keeper to hold and finish assembly.
flthd31 flthd31 is offline
Sportster/Buell Year: 1971
flthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to beholdflthd31 is a splendid one to behold
Here's the pic in question:
Blairjesse's Avatar
Blairjesse Blairjesse is offline
Sportster/Buell Model: Ironhead xls
Sportster/Buell Year: 1983
Blairjesse is an unknown quantity at this point
ride like lightning...
Blairjesse's Avatar
so as of now. I had ran the bike in gear to se if the oil was flowing from the hole. and it was. I cleaned the area. installed gasket, and retainer. put some sealant on the sprocket splines and installed it. I'm going to give it 24 hours to set..and give her a rin tomorrow to see how she does.
Blairjesse's Avatar
I will try this method if how I tried today doesn't hold.
Captx Captx is offline
Sportster/Buell Model: Xlx
Sportster/Buell Year: 1883
Captx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura aboutCaptx has a spectacular aura about
I have an 83 Ironhead that would leak like a pig every time I would ride it. I looked everywhere on that bike and could never find out where it was leaking from. Then I believe I read on one of the threads in this forum about the oil tank having cracks on the brackets for the battery holder welded onto the oil tank. Sure enough I found two large cracks right on the welds. I repaired the welds on the oil tank and then I welded the battery holder to the frame itself. My bike is pretty much oil leak free now, maybe one drop per month. Hope this helps
Blairjesse's Avatar
FYI, thanks everyone for the input. I used a sealant on the shaft splines and regasketed the oil seal and it seems to be holding well. this xl forum is great
