0 69 xlch won’t start
0 Generater light question
Last Post: Doc308
0 Compression Measurement - Look Here
0 Hammer 1275 UPDATE...
0 clutch gear change out
Last Post: Randy_rots
0 Heel Toe Shifter?
Last Post: Bigport
0 hydraulic lifter test?
0 1970 Harley-Davidson Streamliner
0 Never imagined I'd own a Harley
Last Post: br0qn
0 Sloppy up-shifting when hot?
0 White smoke out of tail pipe after engine build?
0 I'm A Noob
0 Idle speed screw thread size
0 Sportster R.I.P.
Last Post: JunkyardDog
0 U.S. Nat'ls Moto Trials 2021 Western Rd
Last Post: marcusorelius
0 Allegheny National Park
0 Fork question
Last Post: zukinut
0 Opinions-checking oil level 2006 1200L
Old 19th May 2016
Truckedup Truckedup is offline
Sportster/Buell Model: 883
Truckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of light
Default One less tooth front pulley question
This is actually a Buell question , figure I will get more opinions here ...
97 Buell stock 27 tooth front pulley and and 61 tooth rear. 128 tooth belt, axle adjuster is about in the middle of the slot with a loose belt adjustment used on tube frame Buells.
I want to use a 26 tooth front pulley .....Do you think the one less tooth front pulley will have the axle adjuster at the rear limit of travel? Thanks
650 Triumph LSR modified production pushrod 133.1 mph....
Old 19th May 2016
Folkie Folkie is offline
Where you post really doesn't make any difference to how many replies you get. The thread appearing on the Active Threads page is what matters.
On the other hand, if it's posted in an entirely inappropriate thread, how would anyone who's interested in the subject find the thread in future in order to benefit from the discussion.
Old 6th June 2016
The 26 tooth pulley is on ...The rear axle is slightly less than 2/3's of the slot adjustment with the stock drive belt...
Old 30th November 2016
jkinkade jkinkade is offline
Hope i'm not too late here.
You can use stock belt with the 26 front sprocket. i prefer this gearing myself.
Yes, he already said that he did that; it used only about ⅔ of the adjustment slot.
