Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 69 xlch won’t start
0 1970 Harley-Davidson Streamliner
0 Generater light question
0 clutch gear change out
0 Compression Measurement - Look Here
0 Hammer 1275 UPDATE...
0 Heel Toe Shifter?
Last Post: Bigport
0 hydraulic lifter test?
0 Never imagined I'd own a Harley
Last Post: br0qn
0 Sloppy up-shifting when hot?
0 White smoke out of tail pipe after engine build?
0 I'm A Noob
0 Idle speed screw thread size
0 Sportster R.I.P.
Last Post: JunkyardDog
0 U.S. Nat'ls Moto Trials 2021 Western Rd
Last Post: marcusorelius
0 Allegheny National Park
0 Fork question
Last Post: zukinut
Last Post: 84rzv500r
0 Opinions-checking oil level 2006 1200L
Old 23rd August 2014
nitrous jim nitrous jim is offline
Sportster/Buell Model: s1
Sportster/Buell Year: 01
Sportster/Buell Model #2: nitrous s1
Other Motorcycle Model: 10 second nitrous shovel
Other Motorcycle Year: 1971
nitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of light
Default chain gaurd/ motor brace/ sprocket cover
I was sick of getting chain oil all over my motor. Just to the left of the "chain guard is a piece of delrin to keep the chain from sawing through the frame.
the clear hose was temporary. I made a new oil tank and wanted to watch the oil move around. you can also see the starter button and the cut up cam cover
[IMG]http://[/IMG]
from the side.
