Last Post: Nicktater
0 Sportster book
Last Post: 1200CustomHD
0 What jets do you use?
Last Post: Thack
5 Red Shift cams similar to Jackhammer 570 ?
Last Post: Clevspeed
0 My 08' Nightster
Last Post: XL1275
Last Post: XL1275
Last Post: Seek4aws
0 Year electronic diagnostics started
0 72 heads, do these look normal?
0 Hard saddle bags -
Last Post: Samedward
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
0 $700 Ironhead ? Good value? depends who you ask
Last Post: DollarBil
crane, ignition, ironhead, points, single fire
Old 9th April 2016
Kickflippin Kickflippin is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: Yamaha XS650
Other Motorcycle Year: 1978
Kickflippin is an unknown quantity at this point
Default Switching back to points from Electronic Single Fire
I had a Crane Hi-4 Single fire fail on my '76 XLCH. I can't afford a new electronic ignition right now but I do have a good points assembly here.
Can I even run points with a single-fire coil?
If so, how would I change the wiring to power the points breaker?
I'm running kick-only, with no tach or VOES so its only the 3 wires from the unit. Thanks!
Old 9th April 2016
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
With a single set of points you would have to rewire the coil to dual firing or simply replace the coil with one that is dual fire rated for points
Old 9th April 2016
How would i rewire that? Splice one wire to run to both front and rear cylinder posts on the coil?
Thank you
Old 9th April 2016
ignition systems are based on the ohm`s of the coil. you might be able to link the 2 coils together but the ohm`s may be way off and either degrade the coil output voltage or burn the points from the high current
Old 9th April 2016
8ball's Avatar
8ball 8ball is offline
Bike Builder
Sportster/Buell Year: 1973
Sportster/Buell Model #2: xlch stroker
8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of
I just did the same thing to the 74 stroker I picked up same ei ...I had a points plate switched back and spliced the wires didn't work well... picked up a cheapo lot off epray and all is well in the world well bike wise atleast...swap ir to points their more work but you can see what their doing and fix em if their not doin it
"ya...i saw a guy do this once... " -DR DICK
Old 9th April 2016
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Without opening up the coil, I don't know of a way to wire up a single fire to make it a double fire. Either new coil, or new ignition.
[IMG]http://i.imgur.com/Oe4Ttw0.png[/IMG][IMG]https://i.imgur.com/AFv3AMo.jpg?1[/IMG]
Old 9th April 2016
Smerch's Avatar
Smerch Smerch is offline
Sportster/Buell Year: 1979
Smerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to beholdSmerch is a splendid one to behold
I can't offer any help on switching to points, but since I am running the same HI-4 ignition I'm curious about how it failed.
Did it give you any kind of warning or did it just go belly up one day?
Old 9th April 2016
doodah man's Avatar
isn't that how they do? fine one day, then the next - croak!
kick - if you have an indy near you, why not drop in make friends and see if they have a dual fire coil they will trade you?
Old 9th April 2016
8ball's Avatar
Bike Builder
Who ever installed mine for the po snagged the wire cover pretty good fishing it through the cam case eventually it wore through all the way and shorted the whole deal...probably the reason the po parked it in the first place
Old 9th April 2016
jeffro57 jeffro57 is offline
Sportster/Buell Model: custom
Sportster/Buell Year: na
jeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to beholdjeffro57 is a splendid one to behold
get dual fire coil, sell old coil on fleabay, rewire of current coil waste of time,
