Last Post: Clevspeed
0 My 08' Nightster
Last Post: XL1275
Last Post: XL1275
5 Red Shift cams similar to Jackhammer 570 ?
Last Post: Seek4aws
0 Year electronic diagnostics started
0 72 heads, do these look normal?
0 Hard saddle bags -
Last Post: Samedward
Last Post: Cablejudge
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
0 $700 Ironhead ? Good value? depends who you ask
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
alarm, fuse, ignition, key fob, no start, relay, tssm, wont start
Old 9th June 2018
gaspasser's Avatar
gaspasser gaspasser is offline
gaspasser is on a distinguished roadgaspasser is on a distinguished road
voltage says 10.9 its low...no doubt there. i'm gonna get a new battery today and see where that goes.
Old 9th June 2018
sportsterdoc's Avatar
sportsterdoc sportsterdoc is online now
10.9 for a, b or c?
What is battery voltage:
a. key off?
b. key on?
c. while pressing start button?
Both ends of both battery cables thoroughly checked?
Old 9th June 2018
gaspasser's Avatar
ok...went and got the battery load tested. its totally fine......battery is 100%
thinking either voltage reg or TSSM??
Old 9th June 2018
1. Under what condition did you read 10.9 volts?
2. What is the condition of both ends of both battery cables?
3. What is voltage with motor running at a fast idle?
1. KEY OFF battery voltage, at the battery: Normal is 12.8, acceptable is 12.6 (standard lead acid battery, not AGM) to 12.8 for no load. In the case of a bad cell, the other cells overcharge and give an almost normal reading, until load is applied.
• If lower, then battery is discharged and needs charging or
• Battery has a bad cell
2. KEY ON battery voltage (headlight on): Normal is not under about 12.5 initially, but will decline the longer that the headlight is on, without the motor running. Under no load, 12.5 volts indicates 50% discharge, but under load, it is just voltage drop.
• Battery has a bad cell or
• Battery cable(s) have high resistance
3. KEY ON battery voltage while cranking: Normal is not under 10.5 volts
• Battery cable(s) have high resistance or
• Starter is drawing too much current
4. If the bike is running, battery voltage at about 2,500 RPMs should be 13.8 to 14.8
• If not, then check stator resistance and regulator ground
• If the stator is not shorted to ground and resistance is within spec, the regulator or regulator ground is suspect
Old 9th June 2018
jbee jbee is offline
Sportster/Buell Model: XR1200
jbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond reputejbee has a reputation beyond repute
Have you checked for trouble codes via speedo diagnostics?
When you first turn the bike on and it doesn't start, does the engine management light come on in the speedo for 4 seconds? Does the red security light come on and go off after 4 seconds?
There are three fuses which interact with the TSSM. The ignition, the accessory and the battery/security fuse. Can you confirm which fuse by its location in the fuse block you are removing and reinstalling to allow the bike to start? i.e. top left, bottom right.
Old 10th June 2018
Glad to see you jump in, jbee, as the security system is not my forte.
However, we still have some unanswered voltage questions, going back to post 2.
Old 10th June 2018
It is extremely frustrating when the OP is unwilling to reply to direct questions with the actual information that was requested - Q:What did you eat for breakfast? A:Food - Q:Can you be more specific? A:Left overs
Long distance help requires good communications - What EXACTLY did you do? What EXACTLY did you see happen as a result? At what EXACT point did you measure the voltage? What EXACTLY was the meter reading?
tried pulling fuses etc. discovered if i pull the fuse for the blinkers and reinsert it starts just fine.
There is no 'Blinkers Fuse'... Which fuse was it?
also, came out to the garage and discovered my running lights on and the bike was completely turned off.
Did you open the TS housing to see which element was ON? Are you 100% sure it was the Running element & not the Turn Signal element? Was the headlight on (very dim)? Were any rear lights on?
Is it still doing this??
2 Relax
Old 10th June 2018
Hippysmack's Avatar
discovered if i pull the fuse and reinsert it starts just fine.
No power then pulled a fuse, put it back in and now power.
Has it been sitting in a lot of rain lately?
Corrosion building a bridge between fuse box contacts or maybe the on/off or ignition switch?
Shorted wire behind the fuse box,?
Mine was blowing headlights left and right when I bought her due to a corrosion bridge in the bucket.
Old 10th June 2018
gaspasser's Avatar
the fuse is the 3rd one down on left side of the block
Old 10th June 2018
gaspasser's Avatar
things i have done rto resolve this issue:
1-charged battery.
2- had battery load tested and its fine
3- Replaced Starter Relay
BTW (battery connections are pristine)
4-Replaced Key Fob battery in case it was related to security system
and excuse me the fuse was 2nd one down on the left side of the fuse block
