0 Brand new 2020 XL1200NS
5 Cruise-Mate (Europe)
0 Down on oil
Last Post: Billy1200
0 Vintage tires
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
  #71
Old 8th August 2019
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Originally Posted by Maxeffort View Post
Are both of these the same bike? What cams in the second graph?
Yes, both of those charts are from the same bike, but the two sheets reflect very different motor configurations. This is our shop test bike and we've run everything you can imagine on it at one time or another, from a basic conversion up through our 120+hp package making 132hp. And we've run a whole ton of experimental combinations as well.
In that second sheet, the motor had our IMPACT 560 cams. But it had other motor mods as well.
Click Here to Contact Me
Old 8th August 2019
aswracing's Avatar
Originally Posted by Highly-Dangerous View Post
Hi there,
I have sent you a couple e-Mails... one two weeks ago and the second one two days ago.... no reply yet.
Waiting... waiting...
Cheers.
Alex answers most emails these days. Are you sure you haven't received an answer? Nine times out of ten, when a guy doesn't hear back from us, it's because it went to his spam folder.
Old 8th August 2019
Highly-Dangerous's Avatar
Highly-Dangerous Highly-Dangerous is online now
I am positive. always check the spam folder just in case... nada.
Cheers.
Old 8th August 2019
aswracing's Avatar
Cheers.
Shoot me a note at aaron@hammerperf.com
Old 8th August 2019
Done!
Old 19th October 2019
Ghostdog's Avatar
Ghostdog Ghostdog is offline
Sportster/Buell Model: Sportster iron 883>1275
Sportster/Buell Year: 2016
Ghostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to allGhostdog is a name known to all
I found this post after some searching. and it’s a good comparison of cams into the 240’s @ .053”.
I was wondering if I could use the hammer 570 cams in my bike ? 2016 iron 883>1275 with ported 883 heads. I was able to get the Andrews n4 cams to work and they are currently in my bike . But I would love to try the 570 cams . Do you guys think it could work? If it doesn’t work then what else would need to be done to my heads ? Would it cost a lot to rework the heads in order to run 570 cams? Is there that much clearence difference between the n4 and 570 that would push it to far or are they close clearence wise ? Thank you for any help you can offer . And I hope I’m not out of line asking for help in this thread.
Ghostdog 2016 iron883<1275 Hammer prefomance kit, energy one extra plate clutch, 15percent spring,N4 cams, ported 883 heads ,danmoto 2-1 exaughst ,Dynojet powervision tuner .
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Two main things have to be considered when increasing lift.
1) There has to be enough valve to piston clearance.
2) The valve spring has to be able to handle the lift.
Ghostdog's Avatar
Understood, The reason I ask is because an Aarons chart on their test bike they use the 883 heads. And I have the new 883 With the newer spring pack saying this is I believe, But he said the tolerance is very close with the 883 hits but they got it to work. So I was wondering since I have the newer 883 heads and I have aftermarket cams If I I would have any luck with them fitting in mine as well.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
And valve to valve clearance during overlap.
Maxeffort's Avatar
I'm under the impression that Hammer pistons have extra deep valve reliefs.
It's always best to measure of course.
If you measured V to P with the N4's, they may know if you'll have enough with 570's
